trouble with mods(1994 EX Accord)
Old Jan 21, 2005 | 09:55 AM
cookb's Avatar
Default trouble with mods(1994 EX Accord)
I have a 94 accord EX. And just installed a msd cap and coil also I installed a adjustable fuel regulator and now I,m reving up to 5,000 ok but past 5,500 I get a hesitation, can some one with these mods help out.
poa ecu( no rev limit,no fuel cut off, 8500 red line.
dc header P.S. ( I need to know a good setting for the fuel regulator)
front mount intake
2.5 inch exhaust
hIGH FLOW CONVERTER
obx pipe 4.5 outlet
iriduim plugs
obx 10.3 wires
Can any one help with these mods?
Old Jan 21, 2005 | 10:06 AM
iam7head's Avatar
Default Re: trouble with mods(1994 EX Accord) (cookb)
let me guess, you raise the Fuel pressure to 55PSI and running uber rich and the car bog down
your front mount intake is wasting you gas, you probably will see a drop in performance because of it.
Old Jan 21, 2005 | 12:42 PM
fknslmd's Avatar
Default Re: trouble with mods(1994 EX Accord) (iam7head)
how does your f22 like to rev up to 8500?? i bet it makes tons of power up there lol!
Old Jan 21, 2005 | 01:15 PM
Hawkze_2.3's Avatar
Put the stock parts back on and see if you still have hesitation.
Front mount intakes are completely stupid.
Old Jan 21, 2005 | 05:07 PM
JonnySBeee...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cookb &raquo;</TD></TR><TR><TD CLASS="quote"> I have a 94 accord EX. And just installed a msd cap and coil also I installed a adjustable fuel regulator and now I,m reving up to 5,000 ok but past 5,500 I get a hesitation, can some one with these mods help out.
front mount intake
2.5 inch exhaust
hIGH FLOW CONVERTER
obx pipe 4.5 outlet
iriduim plugs
obx 10.3 wires
Can any one help with these mods? </TD></TR></TABLE>
is there a need to redline that high....6k is good enough for f22
Old Jan 22, 2005 | 04:53 PM
srfnscubamunkey's Avatar
you know im new to this board but reving a f22 to 8500 is dumb as ****... mainly because of its R/S ratio and plus it stops making power around 6500
go ahead and shift at 8500 a golfcart will kill you on the strip
dumb people kill me go blow your motor up maybe youll learn
Old Jan 22, 2005 | 05:02 PM
ProjectDarkBlack's Avatar
Default Re: trouble with mods(1994 EX Accord) (srfnscubamunkey)
sounds like a problem with the fuel pressure regulator and/or ignition problem. That and the fact that you bought OBX parts. By a performance intake please, not a front mount advertisement for the automotively impared
Old Jan 22, 2005 | 07:13 PM
FSTASNTZ's Avatar
You bought an adjustable regulator, but did you buy a gauge to go with it? If so, what is your fuel pressure at idle?
Jason
Old Jan 22, 2005 | 08:35 PM
jagged4698's Avatar
Default Re: trouble with mods(1994 EX Accord) (FSTASNTZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srfnscubamunkey &raquo;</TD></TR><TR><TD CLASS="quote">and plus it stops making power around 6500
Just because the red line is set at 6500 doesn't mean the power band goes that high. Right between 5200 and 5500 is where a stock f22 should stop making power. Waiting until the line to shift is worthless.
As for the problem with your car bogging down. It could be a mix of a lot of things. The first thing i would suspect is you fuel regulator. Then the next thing i hear a lot is that those larger plug wires make the car bog for some reason... Happened to me and happened to a friend. Stock plug wires should give you enough spark for your car to run fine... Not sure why you have all these extremely worthless mods? But quit believeing everything you read.
Old Jan 23, 2005 | 07:35 AM
SuperSlow's Avatar
Yeah... nothin like spinning a bearing or throwing a rod.
Old Jan 23, 2005 | 01:14 PM
Default Re: trouble with mods(1994 EX Accord) (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">Yeah... nothin like spinning a bearing or throwing a rod. </TD></TR></TABLE>
spun a bearing once before wont do it again...i learned the hard way
sageuvagony
Feb 2, 2014 10:30 AM
