b18 swap
Old Jan 21, 2005 | 08:36 AM
delsol31603's Avatar
Default b18 swap
what will i need to do a b18 swap in my del sol
Old Jan 21, 2005 | 08:54 AM
Lee_Delso's Avatar
Default Re: b18 swap (delsol31603)
https://honda-tech.com/zerothread?id=878010
Old Jan 21, 2005 | 08:55 AM
Kyles ej1's Avatar
Default Re: b18 swap (Lee_Delso)
u need a search
mwieczorek43's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol31603 &raquo;</TD></TR><TR><TD CLASS="quote">what will i need to do a b18 swap in my del sol</TD></TR></TABLE>
Come on man. Whats wrong with you!!??
Old Jan 21, 2005 | 09:01 AM
92orangeeg's Avatar
search.........search..........search ^
type in b18 swap__________________________________-
Old Jan 21, 2005 | 09:02 AM
hawaiianbro's Avatar
lol well you could start off by
1-using the search
Old Jan 21, 2005 | 10:01 AM
b18CivicEx's Avatar
i got a b18 swap done...
good pick
Old Jan 21, 2005 | 10:14 AM
3.point.2's Avatar
right now theres two swap questions on the first page of this forum that can EASILY be answered by reading the swap post at the top of the page or searching.
Old Jan 21, 2005 | 10:18 AM
KevronsEG's Avatar
Default Re: (b18CivicEx)
all of you are asses just help the guy out thats what we are all here for to HELP each othe rnot be asses and tell him to search. i own a del sol also and i have been looking into swaping b18b and here is what i have got so far.
b18b/tranny/ecu
use your engine harness
you need the 94-00 integra rear "L" bracket
you need the 94-00 integra dr. side mount
you use your civic tranny mount
use the 94-00 integra frount mounts tranny side and dr. side.
if want to keep a/c you need the dr. side front mount from type R or b16 del sol
Shift Linkage YOU NEED Del sol b16 linkage NO OTHER OPTION
Axles and intermediate shaft need to be from same year cars. (if 94-00 intemediate shaft then you need 94-00 axles.)
and you will need upper and lower rad. hose form 94-00 integra
hope this helps if any more questiosn PM me
Old Jan 21, 2005 | 11:27 AM
losder riper's Avatar
Default Re: (IAmTheRealKevron)
THE REAR L BRACKET OF INTEGRA WONT WORK YOU NEED ONE FROM B16 DELSOL
Old Jan 21, 2005 | 01:27 PM
beerbongskickass's Avatar
Default Re: (losder riper)
I would also add a B16/GSR head and B16/GSR tranny to your list of things if your swapping in a B18B1.
Old Jan 21, 2005 | 01:32 PM
KevronsEG's Avatar
Default Re: (beerbongskickass)
see learn soemthing new everyday
Old Jan 21, 2005 | 01:42 PM
Shorter tranny gearing and a vtec head make it fun!
Old Jan 21, 2005 | 07:27 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">I would also add a B16/GSR head and B16/GSR tranny to your list of things if your swapping in a B18B1.</TD></TR></TABLE>
at a minimum a gsr tranny. it makes my ls much more responsive. b16 trans on an ls might be overkill to drive daily. and your top speed is only like 110mph
Humantippin
May 4, 2015 02:58 PM
BedDeMoN
Jun 27, 2009 12:23 AM
nthao89
Dec 4, 2008 07:36 AM
shugahkane
Nov 11, 2006 04:53 PM
j-bird
Jan 15, 2005 06:36 PM
