Thnk I blew some fuses... Help me out
I had my system hooked up, got 2 10's and a 800 watt amp. I accidently pulled the amp to far and my power wire popped out and hit one of the screw u screw in the speakers wires into and the system and everything shut off.
I yelled because I just spent 80.00 on getting my headunit and everything hooked up. I have a 2000 Honda Accord lx, I've got 3 fuse boxes as far as I know, I checked all 3 of them and I couldnt find any fuses blown. Im pretty sure its a fuse, because none of my speakers work, my headunit doesnt turn on, and my cigerette lighter doesnt wok either because I usually charge my phone but it wont work now.
Is there anymore fuse boxes, or fuses anywhere I can check... What should I do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by casmello »</TD></TR><TR><TD CLASS="quote">I had my system hooked up, got 2 10's and a 800 watt amp. I accidently pulled the amp to far and my power wire popped out and hit one of the screw u screw in the speakers wires into and the system and everything shut off.
Is there anymore fuse boxes, or fuses anywhere I can check... What should I do.</TD></TR></TABLE> Did you check the fuse box in the engine bay ?
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sdinteg »</TD></TR><TR><TD CLASS="quote">Shouldn't the amp have its own power wire running directly to the battery? The fuse would be in-line with this wire next to the battery and not in any special compartment.</TD></TR></TABLE>Even if the amps power wire fuse was blown it would not keep the HU from working
94
94
jadugartir
Audio / Security / Video
Apr 14, 2005 09:26 AM
