zc ready to drive but motor wont get gas
Old Jan 21, 2005 | 04:50 AM
evilsolb16's Avatar
Default zc ready to drive but motor wont get gas
we put a zc in a 91 dx, wired for mpfi, finish hookin everything up, went to start it and it would spin over but not start, check spack and compression then check for gas, fuel pump is pumpin and its getting to the fuel rail but not going throw the injectors. the motor has been sitting for a long time looks like it wasnt stored very well. i think that the injectors may be bad.
Old Jan 21, 2005 | 06:53 AM
MONSTERZC's Avatar
Default Re: zc ready to drive but motor wont get gas (evilsolb16)
double check your wiring i bet thats where the problem is
Old Jan 21, 2005 | 06:57 AM
HumanResource's Avatar
you are using a MPFI ECU right?
Turn the motor over and over with the spark plugs out to make sure the injectors are not firing.
If it starts to smell like gas, then it's not the injectors by themselves.
Old Jan 21, 2005 | 07:52 AM
evilsolb16's Avatar
Default Re: zc ready to drive but motor wont get gas (HumanResource)
checked injectors already, pulled out plugs nothing no hint of gas at all. check wiring. the only thing that im not sure about if the resistor box, it said to use yellow wire with the black line on it from the dx harness as the power for it but i think that the injector are old and stuffed up or its the resistor box. any help or pic on how it should look when your done wiring the resistor box
Old Jan 21, 2005 | 08:00 AM
Slopoke's Avatar
Have you checked to see if you are getting any power to your injectors?
What ever wires you have running from the resistor box to the injector should have 6-8volts, when the ignition is on.
Make sure you have that.
Old Jan 21, 2005 | 09:38 AM
jlicrx's Avatar
Default Re: zc ready to drive but motor wont get gas (Slopoke)
do you have the ground for the ECU connected at the thermostat housing?
Old Jan 21, 2005 | 10:04 AM
evilsolb16's Avatar
Default Re: zc ready to drive but motor wont get gas (jlicrx)
yeah. most the time if you dont have that hooked up then you want have spark. i got spark but no gas
Old Jan 21, 2005 | 03:38 PM
vegaskurt's Avatar
Check your wiring with this guys site, sounds like the same setup.
http://www.fourthgenhatch.com/mpfi.html
Which resistor box are you using? your not using the one off the dx are you?
zchatch24
13
Feb 26, 2012 08:47 AM
EGhatch22
Jun 7, 2007 03:21 PM
n2oef
Jan 21, 2005 12:54 AM
Sobe_Death
Mar 13, 2004 02:02 PM
CrX1988Zc
Aug 19, 2002 02:40 PM
