are the rear disc brake off a 1992 si the same size as the 99 si and 94+ integs?
Old Jan 21, 2005 | 01:40 AM
stripes777's Avatar
Default are the rear disc brake off a 1992 si the same size as the 99 si and 94+ integs?
or would a set up off a teg be better
thank you
Old Jan 21, 2005 | 04:24 AM
pdiggitydogg's Avatar
yes theyre ALL the same
searching would have told you that
Old Jan 21, 2005 | 04:35 AM
rasinhell's Avatar
Default Re: (pdiggitydogg)
seriously? I thougth GSR brakes had superior stopping power or something.
Old Jan 21, 2005 | 04:37 AM
sockvtec's Avatar
Default Re: (Special-Ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Special-Ed &raquo;</TD></TR><TR><TD CLASS="quote">seriously? I thougth GSR brakes had superior stopping power or something.</TD></TR></TABLE>
yea i thought that the rears were just a lil bigger in the tegs, cause mine look really small compared to my friends gsr, but maybe its just me
Old Jan 21, 2005 | 04:52 AM
Rears are all the same...
*sigh* I dont know how many times I have to say THAT and the fact that gsr's do not have bigger brakes than any other integra up front OR rear.
Old Jan 21, 2005 | 05:18 AM
mzboy's Avatar
I'm pretty sure you'll find the answer to your question + every other question you'll have about brakes some where in this thread
https://honda-tech.com/zerothread?id=152884
Old Jan 21, 2005 | 06:36 AM
Grip's Avatar
Default Re: (mzboy)
92cx and 92 si front disc's are the same
92 si rear brakes are smaller than 93-95 si/ex rear disc's
i picked up 92 si rear disc's for my 92 cx because i allready have 92 cx front brakes which ar the same as 92 si front brakes..which means all i need'd was a 40/40 prop valve to finish the swap since the 92 cx and 92 si share the same master cylinder and brake booster
Old Jan 21, 2005 | 07:12 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (Grip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip &raquo;</TD></TR><TR><TD CLASS="quote">92 si rear brakes are smaller than 93-95 si/ex rear disc's
This statment is completely UN-TRUE. Civic/Sol/Tegs have had the EXACT same rear discs from 1988-2000. If you don't believe me, crossreference the part numbers on http://www.hondaautomotiveparts.com. The ONLY one that is different is the Integra Type R (& JDM/UKDM Civic Type R). The rotors are about .75" bigger in diameter, but thats it.
With the exception of the type R, all those brakes & suspension parts are interchangable.
Old Jan 21, 2005 | 07:41 AM
Grip's Avatar
Default Re: (94eg!)
it might be untrue..but all i know is my local napa autoparts store cross refrenced part #'s and we found that the 92 si rear brakes are smaller ..maybe just the fronts are diffrent
Old Jan 21, 2005 | 08:10 AM
fronts are the same as non-abs si hatches.
ALL REAR DISCS ARE THE SAME DAMN PARTS.
Jesus, I could stay away for over a year and then still see the same damn questions.
longshot
Oct 21, 2008 07:03 AM
nitewolf
Sep 20, 2007 11:12 AM
rexfan
Mar 15, 2007 11:49 AM
TyConway21
Sep 10, 2006 02:41 AM
camp1320.com
Mar 9, 2005 12:56 PM
