help window issue.. 00 civic si 50k
Old Jan 20, 2005 | 06:38 PM
madlion's Avatar
Default help window issue.. 00 civic si 50k
alright i have a problem with my window.. i can push the switch down and the window will go down.. but it wont go up when i push it up on the passenger side.. if i use the other switch on the drivers side it will go up real slow.. i was thinking i needed a switch because i thought the switch was flubbing up.. but i was informed i need a power window regulator.. anyone know if i need the motor or is the power window regulator included with the motor or do i need a motor.. and where can i order this for a good price at?
Old Jan 20, 2005 | 06:56 PM
The AntiRice's Avatar
Default Re: help window issue.. 00 civic si 50k (madlion)
this is the wrong forum but take a look at the drivers side switch panel and make sure it is not set to "lock" which will disable the passenger side switch.
brent_si
Honda Civic (2006 - 2015)
Sep 18, 2014 09:11 AM
lucfleclerc
Apr 25, 2013 01:55 PM
red civic standard
Jun 26, 2009 07:41 AM
MtbikingKing
May 5, 2006 09:27 PM
madlion
Jan 20, 2005 04:07 PM
