what is this? and why is it leaking? clutch related
http://www.we-todd-did-racing....=.jpg
its on the inside of the firewall and its the thing the clutch pedal is connected to i know what is does just need to know what its called and why its leaking. thanks
and how do i put the picture in the post?
do you have any problem with clutch pedal engagement? is there any problem causing you to not shift propertly??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">looks like you might be leaking clutch fluid, get it fix before it start chewing your car up!!</TD></TR></TABLE>
i dont think its clutch fluid its more thick and black like grease and its not poring out just barely a drip i just noticed it the other day whats my problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">do you have any problem with clutch pedal engagement? is there any problem causing you to not shift propertly??</TD></TR></TABLE>
the clutch engages when the pedal is almost all the way out but i think thats cause my clutch is worn and needs replacement.
the seal inside the master cyl is bad. rubber o rings/seals/gaskets wear out over time due to surrounding elements, extreme heat/cold/pressure/corrosion ect. Its leaking brake fluid so it should be replaced.
does your clutch have less pressure behind it now? meaning, is it easier to push in? if it is then there is probably air in your system due to air taking the place of the leaking clutch fluid..
Replace your clutch MC. The thick black like grease is from all the rubber & plastic
parts that are being melted by the brake fluid. A new one isn't very expensive,
and it's really easy to install. Remove, Replace, Blead Fluid, Done. And wash all
the areas with soap & water, that the fluid has gotten on.
