problem with wiring bunching up at spool area
Old Jan 20, 2005 | 05:47 PM
THE BEAST's Avatar
Default problem with wiring bunching up at spool area
I have a Hobart Handler 140 and ever since I got the welder on occassion it will jamb up. I have adjusted the tensioner and have it on the correct wire size/setting. I cannot figure out why it keeps jambing up. I am using the correct wire.
Any suggestions or did I possibly set this up wrong?
TIA
Old Jan 20, 2005 | 07:35 PM
fknslmd's Avatar
Default Re: problem with wiring bunching up at spool area (THE BEAST)
we have a lincoln at work that does that from time to time and boy is it frustrating.
Old Jan 20, 2005 | 08:12 PM
Engloid's Avatar
OG Fabricator
It can be caused by having too many bends in your lead cable. Bends add resistance that fights the wire's efforts to move through the liner of the lead. It can also be that your tip is dirty or has something obstructing smooth movement of the wire. Basically, one way or another, your rollers are pushing the wire, but the wire's seeing resistence that's not letting it go through the lead as easily as it should.
Old Jan 21, 2005 | 09:22 PM
boosted-delslow's Avatar
Default Re: problem with wiring bunching up at spool area (Engloid)
The welder that we have at work does that somtimes when the tip gets dirty it jams the wire.
Old Jan 21, 2005 | 09:27 PM
RCautoworks's Avatar
Default Re: problem with wiring bunching up at spool area (boosted-delslow)
A little off topic, but is the spool of wire suppose to unravel like crazy when you take the tape of ? I tried putting on a new spool and if I did not keep a hand on the cable, it would unravel really fast.
Old Jan 21, 2005 | 09:41 PM
triple_s1x's Avatar
Default Re: problem with wiring bunching up at spool area (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">A little off topic, but is the spool of wire suppose to unravel like crazy when you take the tape of ? I tried putting on a new spool and if I did not keep a hand on the cable, it would unravel really fast.</TD></TR></TABLE>
Yup that happens, just always becareful and when you roll it up make sure you dont tangle it.
Old Jan 21, 2005 | 09:42 PM
Default Re: problem with wiring bunching up at spool area (triple_s1x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by triple_s1x &raquo;</TD></TR><TR><TD CLASS="quote">
Yup that happens, just always becareful and when you roll it up make sure you dont tangle it.</TD></TR></TABLE>
Yeah, I actually just cut if off because so much unraveled.
Old Jan 22, 2005 | 12:37 AM
Evil EG's Avatar
Man that is frustrating. It happens to me but only when I use aluminum wire. When I put the wire to weld steel back in its fine.
Old Jan 22, 2005 | 04:22 AM
BoostedH23a1's Avatar
Default Re: problem with wiring bunching up at spool area (Evil EG)
when they unravel on me i toss em out, tightly spooled works alot better, anyway you have to adjust your pressure on the rollers. to do this have the wire out at the tip then put your palm over the tip (so the wire will be pushing on your hand) then u tighten up the rollers until its at the point that it will just spin on the wire when it hits your hand. you dont want it to keep pushing on the wire when it hits something. that in a nutshell is how you set the roller pressure. and like dude said when you weld try to have the least possible bends in the gun.
good luck
Old Jan 22, 2005 | 07:47 AM
Engloid's Avatar
OG Fabricator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil EG &raquo;</TD></TR><TR><TD CLASS="quote">Man that is frustrating. It happens to me but only when I use aluminum wire. When I put the wire to weld steel back in its fine.</TD></TR></TABLE>
That's why people usually use "spool guns" for aluminum...that way you have much less lead to push the wire through. You can also us a "push-pull" gun, that has rollers on the machine that push the wire (like yours), but also has rollers in the head of the gun that pull the wire.
Old Jan 22, 2005 | 07:59 AM
THE BEAST's Avatar
Default Re: problem with wiring bunching up at spool area (BoostedH23a1)
I've messed with the pressure on the rollers several times and have concluded that this was not the problem. I also have made sure there is no loops or kinks. I have gotten really frustrated with this thing b/c it seems like I am constantly re-feeding the sire b/c of the kinks!
nastynguyen
Apr 27, 2010 06:18 AM
San-Wan
Sep 30, 2008 07:28 AM
jdmthug
Mar 11, 2007 11:04 PM
Pikachu
Welding / Fabrication
Apr 30, 2005 09:38 PM
14bcoupe
12
Apr 19, 2005 11:20 AM
