tranny will go into gear with engine on ....tranny wont spin cv's ....speedo moves ...throw out is r
Old Jan 20, 2005 | 03:55 PM
built4cubanlynxx's Avatar
Default tranny will go into gear with engine on ....tranny wont spin cv's ....speedo moves ...throw out is r
d block and z6 ex tranny
no fluid in tranny (should not matter)
tranny shifts into gear but dont move
clutch is grabbing
tranny is slipping inside between the center shaft (or the speedo gear with ever is closer) and the cv joint thanks in advance
Old Jan 20, 2005 | 04:29 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: tranny will go into gear with engine on ....tranny wont spin cv's ....speedo moves ...throw out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built4cubanlynxx &raquo;</TD></TR><TR><TD CLASS="quote">d block and z6 ex tranny
clutch is grabbing
tranny is slipping inside between the center shaft (or the speedo gear with ever is closer) and the cv joint thanks in advance </TD></TR></TABLE>
thats probably your problem....your probably grinding the gears away with all the friction happening with no fluid in it
Old Jan 20, 2005 | 05:29 PM
i dont think it matters i was just try to move car it does not heat up in 2 seconds
Old Jan 20, 2005 | 06:45 PM
mmuller's Avatar
Mad Scientist
if the speedo moves, that means the diff. is moving the vss.
take the axles off and look at the ''teeth'' so see if they are eaten away.
do yourself favor and put oil in that tranny before running it....
Old Jan 20, 2005 | 08:00 PM
IN VTEC's Avatar
Broken axle or maybe stripped splines.
Old Jan 20, 2005 | 08:40 PM
why would gears drop in though without the clutchplate being pressed
the speedo is erratic but spins faster in higher gear
Old Jan 21, 2005 | 12:25 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
just get a new transmission
Old Jan 21, 2005 | 05:50 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built4cubanlynxx &raquo;</TD></TR><TR><TD CLASS="quote">no fluid in tranny (should not matter)</TD></TR></TABLE>Yes it DOES matter!
Old Jan 21, 2005 | 07:19 AM
Little Rascal's Avatar
you have got to be kidding me. everyone should know that you need to put oil in the tranny case before even trying to put it in gear. thats your whole problem. its a hydraulic transmission. looks like your gonna need a new transmission buddy. i have a couple in my garage for sale . sorry to hear. and im surprised it didnt make any loud *** grinding noises or anything when you started it up. think next time
Old Jan 21, 2005 | 07:48 AM
no bud its a hydro clutch slave..................... not a hydro fluid transmission.......u can take the oil out and drive it ...........ive done it
Old Jan 21, 2005 | 07:54 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built4cubanlynxx &raquo;</TD></TR><TR><TD CLASS="quote">no bud its a hydro clutch slave..................... not a hydro fluid transmission.......u can take the oil out and drive it ...........ive done it </TD></TR></TABLE>
dude, stop saying you can drive the ttranny without oil...just because you have done it does not mean its right...
ouch for your synchros and bearings...
Old Jan 21, 2005 | 10:58 AM
this is not helping me find what parts has failed or could be worn bump for some who can
Old Jan 21, 2005 | 11:15 AM
JimBlake's Avatar
Differential must be spinning, since the speedo indicates. So it's gotta be broken somewhere 'downstream' from that.
Actually, the outside of the differential must be spinning. It's possible the spider gears inside the differential have been destroyed. (do those need oil??)
The spline where the axle goes into the diff might be broken. In that case none of the axles will spin. Either side, they don't BOTH have to be broken.
The tripod bearing (inner CV joint) might be trashed. In that case the inner driver spins but the axle doesn't.
The outer CV joint might be trashed. In that case the axle shaft spins, but it doesn't drive the outer CV joint.
The splines where the outer CV joint drives the hub might be trashed. Then the CV joint spins too.
Old Jan 21, 2005 | 12:15 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b2o-vtec &raquo;</TD></TR><TR><TD CLASS="quote">just get a new transmission </TD></TR></TABLE>
x2
Old Jan 21, 2005 | 05:00 PM
not if it was an axel
Old Jan 22, 2005 | 02:22 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
learn how to spell douche
its A X L E !!!!!!
and what do you know? you dont even put MANUAL TRANSMISSION FLUID in your transmission and your wondering why its shot to ******* hell?!?
you should work on cars for a living
Old Jan 22, 2005 | 10:11 AM
Irish Integra's Avatar
Of course you need oil man!! Why would it be in there in the first place otherwise?!!
Anyway one of the inner ends of the shafts may be stripped, and because of the diff, the other side will not drive. jack your car up one side at a time, engine off PUT OIL IN THE BOX, put it in gear and spin the wheel. if the engine turns on one side and not the other, you may just need to replace a shaft. Otherwise, diff is f**ked due to LACK OF OIL
Old Jan 22, 2005 | 10:47 AM
b16hybridsol's Avatar
note to self:
1. class of 04 sucks
2. never buy anything from this guy
3. get milk for breakfast tomorrow
Old Jan 22, 2005 | 02:03 PM
BigMoose's Avatar
Just so you know for next time... With the engine running and the clutch out, the input shaft to the transmission is spinning at engine speed. There are a couple ball/roller bearings on that shaft that is spinning at 1000 to 4000 rpm when you goose the throttle. Last time I checked, even unloaded rolling element bearings required lubricant.
Now for your problem, either the side gears and/or spider gears in the differential are gone, in which case the transmission case will be chock full of metal shavings; or the splines on the inner CV joints and the side gears are bad (stripped) or not engaged on one side... most likely the latter.
boostinnc
Transmission & Drivetrain
Jan 2, 2010 01:37 PM
TurboGoKart
Jun 7, 2006 04:34 AM
HXvtec
Oct 14, 2004 11:27 AM
jlamaster
Jul 30, 2003 12:12 AM
