knocking noise when i make a right turn.....help
Old Jan 20, 2005 | 02:23 PM
mikemcberty's Avatar
Default knocking noise when i make a right turn.....help
ok, so i'm driving home from work, i have a 93' DA, just cruising along and all of a sudden i go to make a right hand turn, and all i hear is grinding. my initial reaction is, torn cv boot. i get home look under the driver's side wheel, but no tears, no leaks no anything. does anybody have any suggestions, before i take it down to the dealer?
Old Jan 20, 2005 | 06:27 PM
whoneedzvtec's Avatar
Default Re: knocking noise when i make a right turn.....help (mikemcberty)
are ur lug nuts tight?
Old Jan 20, 2005 | 06:35 PM
kid-honda's Avatar
I have ran into this problem with my ED's alot, it was caused my torn or bad bushings, check all front ones, and the steering rack bushings.
Old Jan 21, 2005 | 09:56 AM
lugs are tight, i'll have to go through all the bushings then. thanks.
Old Jan 23, 2005 | 10:16 AM
b62pteg#2's Avatar
Default Re: (mikemcberty)
Your CV boot doesn't have to be torn or leaking for the CV joint to be bad. It can simply just fail from its own internal failure. Trust me, the last one I broke, looked fine from the outside but sure as hell didn't go anywhere when shifted Figured it out quick though when I jacked the car up and spun the wheel but the axle didn't spin, lol. Anyway, it's just more common to see the joint go bad bc of a torn boot due to debris and such getting inside and all the grease flying out, causing the joint to go bad (friction, etc). One of the easiest ways to check for a bad CV joint/axle is go to a parking lot and turn slowly, etc. If it's clicking around, then most likely you gots yourself a bad CV joint
HTH -- Kevin
Solstic
Oct 6, 2013 11:06 PM
MyEfSi2Slow
Suspension & Brakes
Oct 29, 2010 09:17 PM
1_slow_crx
Sep 10, 2006 08:29 PM
Toadfart
Jan 26, 2005 08:22 PM
95gsr
Jan 11, 2002 12:35 PM
