Suspension & Brakes Theory, alignment, spring rates....
Hard rubber VS. Poly bushings
Old Jan 20, 2005 | 01:12 PM
JunIntegra's Avatar
Default Hard rubber VS. Poly bushings
There are high durometer rubber and urethane bushings on the market for my car. I was wondering which was better then the other in stiffness, longevity, etc.
thanks
-Chris
Old Jan 21, 2005 | 01:47 PM
RzHybrid510's Avatar
Default Re: Hard rubber VS. Poly bushings (JunIntegra)
Bump! I would like to know also.
Old Jan 22, 2005 | 03:40 PM
travis's Avatar
I think it really depends on the intended use and the specific bushing you're talking about. For a street car I would argue that poly bushings are more trouble than they are worth. The majority of people praising ES bushing kits are comparing them to old, rotten OEM bushings that don't perform as well as pencil eraser material. I imagine that a fresh set of OEM bushings under those circumstances would have been just as good without all of the squeeking and need for lubrication and cleaning. If you have a certain racing application in mind we can talk about each individual bushing and make a plan, but if you're looking to replace old factory bushings I would personally stick with rubber except for maybe the sway bar bushings and shift linkage bushings.
Old Jan 22, 2005 | 05:09 PM
MolecularIntegra's Avatar
Default Re: Hard rubber VS. Poly bushings (travis)
I can support the notion that rubber bushings on a street car are probably a better idea. I replaced many bushings in my suspension with polyurethane and they are a hassle. After 6 months or so I invariably hear squeaking. Let it go on too long and they will start to bind which is unsafe.
Old Jan 22, 2005 | 05:30 PM
JunIntegra's Avatar
Default Re: Hard rubber VS. Poly bushings (MolecularIntegra)
well my car is a 95 240sx and im going to overhaul the complete rear suspension. For those that dont know, the rear is multilink with 16 bushings i beleive not including the diff bushings in the subframe.
So it has tons of rubber and tons of movement and id like to isolate it as much as possible.
It will be a street, Auto-x and HPDE car for the next year or 2 and plans to be in ITS after that.
i was opting for the urethane but the nismo hard rubber is now seeming tempting from what you guys say....
Old Jan 22, 2005 | 06:08 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunIntegra &raquo;</TD></TR><TR><TD CLASS="quote">and plans to be in ITS after that.
If that is the case, I would go directly to http://www.improvedtouring.com/chat2/ and look through the nissan forum for advice. I don't have experience with the 240 rear end, but that is where I would look for the answer.
Old Jan 22, 2005 | 06:21 PM
Bjorn's Avatar
http://www.splparts.com/
for the 240 bushings
Old Jan 22, 2005 | 08:19 PM
JunIntegra's Avatar
Default Re: Hard rubber VS. Poly bushings (Bjorn)
thanks guys. i have already looked into both. ITS runs sphericals which i wont do till racing and spl is exactly where i found the nismo hard rubbers which i think ill go wityh now
DJKellogg
11
Apr 1, 2014 10:47 AM
boostinEJ8
Suspension & Brakes
Sep 12, 2013 09:13 AM
sicegcivic
Mar 2, 2006 07:22 AM
RevEJ1
Oct 9, 2003 05:56 PM
