low beams don't work but high beams do???
Old Jan 20, 2005 | 01:03 PM
dlric's Avatar
Default low beams don't work but high beams do???
anyone ever run into this...
when i turn my headlights on (eg coupe), only the parking lights come on (no low beams). i flick the high beam switch and the high beams work fine. i switch them off and the low beams don't come on.
the funny part is, sometimes if i switch the high beams on and off a bunch of times, eventually the low beams will come on.
i have not done the most logical thing and replaced the bulbs because it seems like the problem is in the switch itself.
anyone encountered this issue yet? it's just really annoying having to high-beam everyone.
Old Jan 20, 2005 | 01:24 PM
sohcvtec1995's Avatar
Default Re: low beams don't work but high beams do??? (dlric)
yea sounds like its the switch, but check the bulbs anyways. could also be the ground.
Old Jan 20, 2005 | 01:39 PM
straggs42d15's Avatar
that kinda happened to me. only my left low beam worked my right one only worked when my high beams were on. so i just changed the right bulb, now they work just fine.
Old Jan 20, 2005 | 01:53 PM
dlric's Avatar
Default Re: low beams don't work but high beams do??? (sohcvtec1995)
yea, my thoughts are it's in the switch. but the bulbs are cheap enough i suppose...i could change them out and see what happens. but when they do work (this started happening a month or so ago...where if i hit the high beam switch once or twice the low beams would come on...
and it has descended to now...where i could sit there for 5 minutes switching the high beam switch on and off and the low beams will never come on.
Old Feb 1, 2005 | 04:57 PM
dlric's Avatar
update...
so i had another headlight bulb and i switched it out...low beams still do not work.
it seems like something in the switch on the steering column must have broke/worn out? there's only one fuse for the headlights...1 bulb that switches btwn high and low so it couldn't be a fuse...?
someone out there must have had an issue like this...
Old Feb 1, 2005 | 10:00 PM
DeuceDeuce's Avatar
I also...HAVE the exact same problem...
Old Feb 1, 2005 | 11:17 PM
b20guy's Avatar
Default Re: (DeuceDeuce)
Sounds like the combination switch. See if you can pull it out and open it up and clean/reinforce the contacts inside. If not try another switch. gluck...
Old Feb 1, 2005 | 11:57 PM
EeeJayEight's Avatar
Default Re: (b20guy)
those bulbs are dual fillament...meaning one is lit for low and two for high....
so yea...check those out before u tear into your switches
Old Feb 2, 2005 | 04:55 AM
dlric's Avatar
that's what im thinking...it's a contact in the switch that went bad or needs to be cleaned. blah...i guess i'll take the thing apart.
it's kind of like my power window switch...one of the contacts got dirty and the switch for my pass window won't work. i've cleaned it, tried to fix it, still doesn't work.
gah!!!
Old Feb 3, 2005 | 03:48 PM
b20guy's Avatar
Default Re: (EeeJayEight)
Yeah but he says intermittantly the low beams work, which would tell me that intermittantly he has power to the low beams, and the ground is probably good since the low beam and high beam probably share the same ground (per side). That would at least rule out fuses and bulbs. Next thing to check would be the switch. Especially if he can play with the switch and it comes on...
Old Feb 3, 2005 | 04:15 PM
all stock's Avatar
check your fuses.
Old Feb 3, 2005 | 04:54 PM
Sivik's Avatar
Default Re: low beams don't work but high beams do??? (all stock)
^^^^^^.... high beams and low beams are on 2 seperate fuses.
Old Feb 7, 2005 | 01:43 PM
all stock's Avatar
Default Re: low beams don't work but high beams do??? (Sivik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sivik &raquo;</TD></TR><TR><TD CLASS="quote">^^^^^^.... high beams and low beams are on 2 seperate fuses.</TD></TR></TABLE>
Old Apr 25, 2005 | 05:50 PM
slotec's Avatar
i have a similar problem i need advice on how to fix. ill be driving at night on the back roads with my highbeams on and when i see a car i flick on my low beams and the headlights shut off completely or sometimes they will get dim and a little bit brighter then dim and then turn completely off. This happens only when i flick to low beams and its happend once when i was crusing with my low beams already on. Do the highbeams and low beams share the same ground?Also when they go completely out ill flick the highbeam back on then back to the low beams and it works again. odd?
Old Apr 25, 2005 | 06:00 PM
slotec's Avatar
Default Re: low beams don't work but high beams do??? (slotec)
anyone?
Old Apr 18, 2015 | 06:37 AM
Chris Lyon's Avatar
Having this problem on my 2005 Odyssey, anyone find a good fix? It's not the switch on the column and its not the bulb.
Old Apr 15, 2016 | 09:56 AM
Bobby Imler's Avatar
I understand if you forgot because it was over 10 years ago but did you figure out why your high beams would work but your lows would not?
Old Apr 15, 2016 | 03:36 PM
Former User's Avatar
Please create your own thread if you have a technical problem.
madchef
Honda Civic (2001 - 2005)
Jul 11, 2016 09:52 PM
trinib20
Nov 24, 2009 02:34 AM
Jhonny Ricer
32
Mar 2, 2007 05:59 AM
jadugartir
Apr 28, 2005 04:35 AM
