is this possible? 91 accord prob
Old Jan 20, 2005 | 11:24 AM
gator-dog's Avatar
Default is this possible? 91 accord prob
i put in a new ignition coil and car ran fine could the ignition coil going out lead to igniter going bad? im just trying to trace this down as car is not even throwing any codes ecu light just stays solid.no blinking what so ever....... and also what does a bad igniterlook like or what are some signs to look for?
Modified by gator-dog at 2:42 PM 1/20/2005
Old Jan 20, 2005 | 06:31 PM
cmrvi1's Avatar
Default Re: is this possible? 91 accord prob (gator-dog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gator-dog &raquo;</TD></TR><TR><TD CLASS="quote">i put in a new ignition coil and car ran fine could the ignition coil going out lead to igniter going bad?</TD></TR></TABLE>
Ok, you put a new coil in the car and it now runs good.
So your question is ..........?????
Old Jan 21, 2005 | 03:28 PM
gator-dog's Avatar
Default Re: is this possible? 91 accord prob (cmrvi1)
no i put a new coil in and it was running fine then started dying sorry i type it f-ed up
Old Jan 21, 2005 | 03:55 PM
cmrvi1's Avatar
Gator,
I know you're fed up with the car, but if you want help, you have to be more specific as to what the car is doing.
My initial guess (and that's all I can do without further info), is that you have a bad ignitor. One question, do you have aftermarket plug wires?
Old Jan 22, 2005 | 09:25 AM
hondadude's Avatar
are you sure that the ignition switch is putting thru power to the black/yellow wire at the dist when the car dies? The ground at the T-stat housing is clean & tight?
How long does it run before it dies? Does the ignition key get warmed up when it's running?
torr
Apr 24, 2024 09:35 AM
nanagsr
Jun 24, 2009 07:04 PM
RacerRex
Mar 17, 2009 06:06 AM
4inspeed
Feb 9, 2004 01:13 AM
gringo7718
Feb 14, 2002 03:42 PM
