hondata datalogging option?
currently im running a lsvtec w/ t4 turbo. i have a hondata i think its a 2b (stage 2). how would i be able to tell? if i want datalogging what will be the easiest way for me to get that option? what if i sell mines and get a s200 what other options would i need? what does the "boost option" includes? is that just the gm 3 bar map sensor?
You can call Hondata with the serial number and they can tell you what system and options you have.
To datalog, you must upgrade to the S200 and purchase the datalogging option. Since you are running a turbocharged setup, you'll also need to purchase the boost option. If you tune you'll want to purchase rom editor.
The boost option does not include any additional hardware...it simply unlocks the boost tables on the ECU's ROM. The 3 bar MAP sensor costs extra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR »</TD></TR><TR><TD CLASS="quote">does datalogging let you see your afr?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR »</TD></TR><TR><TD CLASS="quote">and also do you need a wideband in order to log your afr?</TD></TR></TABLE>
Yes. You also need to synchronize the wideband output voltage with the lambda readout to ensure that the Hondata is datalogging the correct lambda/AFR value.
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZEXGS-R »</TD></TR><TR><TD CLASS="quote">I believe you get the datalogging free now, don't you?</TD></TR></TABLE>
I believe it is still a $200 option.. I don't think they made it free unless there was a special promotion.
pwrofdrm
Oct 10, 2008 09:49 PM
