Should I replace my TIMING belt?
Old Jan 20, 2005 | 08:57 AM
crxh22project's Avatar
Default Should I replace my TIMING belt?
I bought a motor from HMO and i checked the belt and it looks fine to me,
I know its recomended to change it before putting the motor in.
but im kind of low in cash should i go ahead and do it witht the water pump and tensioner. because if you do the belt you have to do the tensioner and might as well do the pump while you are it. so Yeah or nah?
Old Jan 20, 2005 | 09:01 AM
Smokinsax's Avatar
The Boot
so i ASSume, from your handle, that you have an H22? I would recomend changing it out as well as the tensioner. When we did an H22 swap in my buddies Accord he had a <u>hydrolic</u> tensioner that went bad and the timing belt came loose and shredded. From what I know the tensioners tend to be unreliable.
Post in the Prelude forum for some better advice...
Old Jan 20, 2005 | 09:35 AM
RCautoworks's Avatar
Default Re: (Smokinsax)
Of course you should do it now.
Old Jan 20, 2005 | 09:58 AM
Civic138's Avatar
Default Re: Should I replace my TIMING belt? (crxh22project)
Do it now or you could be paying for a new head later on down the road
Old Jan 20, 2005 | 10:14 AM
sabertooth's Avatar
of course u should change all those things. maybe 100 bucks now or a couple hundred down the road. the choice is yours
Old Jan 20, 2005 | 10:18 AM
Default Re: Should I replace my TIMING belt? (sabertooth)
its a b16 you know hi rev motor so it would be a good idea after all uh.
Should i do the water pump too?
Old Jan 20, 2005 | 10:44 AM
johnjw's Avatar
if you have to ask then......yea do it now if you can afford it. Plus its alot easier now to access these parts, i.e you dont have to take off a motor mount.
Old Jan 20, 2005 | 11:40 AM
manson's Avatar
Default Re: Should I replace my TIMING belt? (johnjw)
yes do it now before you put it in. you'll thank yourself later when you don't have to go through all the crap to get it changed in the car.
if you don't have the cash just wait to do the swap.
Old Jan 20, 2005 | 03:02 PM
SuperSteve737's Avatar
Default Re: Should I replace my TIMING belt? (manson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manson &raquo;</TD></TR><TR><TD CLASS="quote">if you don't have the cash just wait to do the swap.</TD></TR></TABLE>
Exactly what I was gonna say. Better safe than sorry, when dealing with swaps. Better to spend a hundred or two now and be safe, then spend several times that in a month or two. My $.02
Old Jan 20, 2005 | 03:25 PM
ef8 h0!'s Avatar
Default Re: Should I replace my TIMING belt? (SuperSteve737)
i didnt even read what you posted, i just read the thread topic, YES REPLACE IT! all of the timing area should NOT be short changed. you will regret it trust me. it's so simple when the engine is out(25-30min), but when its in, plan on about 2-3 hr change.
shadytigger
Feb 28, 2010 08:47 AM
honda94accord
Apr 10, 2007 05:39 AM
b16_madman
May 28, 2005 06:11 PM
ED8DX
Jun 23, 2003 01:51 PM
1hotintegra
Jun 16, 2003 03:10 PM
