JDM EG Factory Headlight w/city lights
Im looking at buying a set of stock stanley jdm headlights for my 94 EG coupe, but i have 1 question. The city lights have a socket, but wehat do i plug into that socket so i have some wires to play with!?
What i did with mine was wirer them to my turn signal and when i turn on my parking lights they came on too. Cause your turn signal is 3 wires and the city lights only have 2 wires.
Are you asking what socket goes in the hole, or where do you wire the socket into?
If you need the bulb, socket, get them from the city lights on a 97 prelude (#5 & 6 in this pic)...
Add to cart here..
Then the plug that goes into them is #9, and the pigtail wires are #5 & #6 in this pic.
Add to cart here..
Add to cart here..
Add to cart here..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad4CiViC »</TD></TR><TR><TD CLASS="quote">Im looking at buying a set of stock stanley jdm headlights for my 94 EG coupe, but i have 1 question. The city lights have a socket, but wehat do i plug into that socket so i have some wires to play with!?</TD></TR></TABLE>
I wired mine to the corner lights. If you're looking for a set of JDM headlights/corners, I have a bunch in stock, just PM me.
what im looking for is trhis....
Usually the socket with the bulb comes with the headlights, i need the plug with the wires, soi can tap into the corners, iknow how to wire it, tahts a no brainer, but yeah, inlinfour.com has the sockets, but nnot the plugs....is this making any sence
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lynxen »</TD></TR><TR><TD CLASS="quote">Better buy the EDM lights, they're glass and made for LHD</TD></TR></TABLE> what does it matter if its lhd or rhd?
The headlight cut off is designed to illuminate the sidewalk & road signs higher up, but not oncomming traffic. If you use RHD headlights, it will be oposite...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">The headlight cut off is designed to illuminate the sidewalk & road signs higher up, but not oncomming traffic. If you use RHD headlights, it will be oposite...
They work fine, I've had them for 4 years w/out issue.
</TD></TR></TABLE>They work fine, I've had them for 4 years w/out issue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MF RODREZ »</TD></TR><TR><TD CLASS="quote">
They work fine, I've had them for 4 years w/out issue.</TD></TR></TABLE>
<FONT COLOR="royalblue"> Same here. I need Raybrigs. </FONT>
yellowjdmcrx
23
Jul 30, 2006 10:20 AM
