Can you Run an A6 si(non Vtec) head on a D15b8 cx
Old Jan 19, 2005 | 06:32 PM
SDT Project EF's Avatar
Default Can you Run an A6 si(non Vtec) head on a D15b8 cx
I have a 92 cx d15b8 and i want to run a 89si A6 head. I have the A6 head on the d15b8, but i think the valves are hitting the pistons? However, right now the time is not correct, which could lead to the valves hitting?. Anyone now if it works?
Thanks to anyone with a helpful response
Old Jan 20, 2005 | 12:45 AM
project dc2's Avatar
Default Re: Can you Run an A6 si(non Vtec) head on a D15b8 cx (SDT Project EF)
your welcome ! lol
and to make it clearer.
SDT is worried the head doenst work with the block . which i told him it would
i was turning the cams to TDC but hit the valves to the piston. i believe. the cams at TDC. but the block is not. #2 and #3 pistons are all teh way up right now and i believe the valves are tapping ( we havent gotten to puttin on the timing belt etcc)
Old Jan 20, 2005 | 01:05 AM
Blind-Fashion's Avatar
the head will work with the block.... all d series (except DOHC ZC) are compatible with eachother.
Old Jan 20, 2005 | 01:49 PM
Default Re: (Blind Fashion)
thanks guys
Old Jan 20, 2005 | 02:37 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind Fashion &raquo;</TD></TR><TR><TD CLASS="quote">the head will work with the block.... all d series (except DOHC ZC) are compatible with eachother.</TD></TR></TABLE>
some of the earlier B8's only had valve reliefs for 8 valves. . .dont know how close the valves get to the pistons, but that may be why. . .
Old Jan 20, 2005 | 07:25 PM
Default Re: (743power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">
some of the earlier B8's only had valve reliefs for 8 valves. . .dont know how close the valves get to the pistons, but that may be why. . .</TD></TR></TABLE>
his has 16 valve reliefs.
Project_EK
Feb 2, 2009 09:23 AM
project dc2
Jan 9, 2005 07:44 PM
drewbie*
10
Jun 12, 2004 04:54 AM
Ignitecivic
Dec 7, 2003 09:23 AM
