obd conversion walk through's?
Old Jan 19, 2005 | 06:04 PM
PHOBIA's Avatar
Default obd conversion walk through's?
does any one have a write up on how to convert every thing to obd1.i know its just a 4 wire o2 and a conversion harness plus a obd1 ecu and distributer.but i would like a walk through or something for reasurance.thanks
Old Jan 19, 2005 | 07:22 PM
CRX_Control's Avatar
Default Re: obd conversion walk through's? (PHOBIA)
when you buy the conversion harness, it should tell you information on how to use it and convert propertly,like blown90hatch makes harnesses with step by step instruction on converting.
Old Jan 19, 2005 | 07:28 PM
PHOBIA's Avatar
oh i didnt know they came with instructions.
ok and one last question about the 4 wire o2 sensors, 2 of the wires zre for a 12 volt source one for the sensore and th eother is a ground? does any one have any tips on how to pass a ref test?
Old Jan 19, 2005 | 07:39 PM
Default Re: (PHOBIA)
also tells you how to do it on in the instructions , all 4 wires should all go into the ecu if you use the harness from blown90hatch.(i use this harness)
Old Jan 19, 2005 | 08:35 PM
eda6's Avatar
Default Re: (CRX_Control)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHOBIA &raquo;</TD></TR><TR><TD CLASS="quote">i would like a walk through or something for reasurance.thanks</TD></TR></TABLE>
Run two more wires for the o2 sensor, install the new parts, read the instructions that came with the conversaion harness. Takes about an hour to get it to run and 2 more hours to make it look good.
I used a blown90hatch harness
Old Jan 19, 2005 | 08:46 PM
PHOBIA's Avatar
ok thanks,for the help.
sh!ft
11
Jul 21, 2011 09:51 AM
Crasian
Sep 15, 2007 04:08 PM
99JdmDc2
Aug 16, 2007 07:43 AM
SkertySkerty
Jul 6, 2007 09:14 AM
kraig8
Jun 22, 2005 02:37 PM
