wheel shaking problem..any ideas?
I was driving home last night and when I accelerated my wheel would yank to the left and kept on doing so...when I got home and parked I turned my wheel back and forth and the whole tire wobbles like the rotars loose or the axle maybe? any ideas? suggestions? appreciate it.
if your wheel is jiggling back and forth it's probably your wheel bearing.. the part that the axle goes into the rotor.. when they go bad there is too much play between the innner and outer sections causing the wheel to move in ways that it shouldnt..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Did you rotate the tires lately? Might want to get your wheels balanced.
shouldnt be a balance problem if he can actually see it woppling.
first thing to check is the lug nuts.
then it can be wheel bearing, ball joint, tie rod, etc.......
</TD></TR></TABLE>shouldnt be a balance problem if he can actually see it woppling.
lug nuts are tight...pretty sure it's something to do with the axle...guess I gotta go to the techs tomorrow thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B30M87A »</TD></TR><TR><TD CLASS="quote">Buy a torque wrench and tighten your lug nuts.
. I forget to what ft./lbs. you have to go to but it's somewhere between 70 and 80 I think.</TD></TR></TABLE>
I usually do 90 on my steelies and 80 - 85 on my rotas..
Check the lugs.. if it's not the lugs jack up the car and see if you can push the wheel in and out.. if so it is prolly the wheel bearing.
. I forget to what ft./lbs. you have to go to but it's somewhere between 70 and 80 I think.</TD></TR></TABLE>I usually do 90 on my steelies and 80 - 85 on my rotas..
80ft/lbs
. I forget to what ft./lbs. you have to go to but it's somewhere between 70 and 80 I think.</TD></TR></TABLE>80ft/lbs
