Suspension & Brakes Theory, alignment, spring rates....
spring height
Old Jan 19, 2005 | 12:44 PM
2khb's Avatar
Default spring height
I will be getting coilover sleeves and ers 400f, 500r, on koni yellows on my '00 hatch. Should I do a 7" or 8" high spring and why?
Old Jan 20, 2005 | 05:03 AM
.RJ's Avatar
.RJ
Default Re: spring height (2khb)
7" front 8" rear
Old Jan 20, 2005 | 06:25 AM
2khb's Avatar
Default Re: spring height (.RJ)
can you explain why use different heights on front and rear?
Old Jan 20, 2005 | 06:53 AM
.RJ's Avatar
.RJ
uh, because thats the correct length for the application?
Old Jan 22, 2005 | 03:56 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2khb &raquo;</TD></TR><TR><TD CLASS="quote">can you explain why use different heights on front and rear?</TD></TR></TABLE>
Those lengths put the perch closer to the middle of the sleeve at a stock ride height or slightly lower. This gives you the greatest available adjustment in either direction. You can go with longer or shorter springs at either end of the car, but you sacrafice some adjustability in one direction or the other. For example, I have had 6, 7 and 8" springs in the rear of my CRX and you can get away with it at certain ride heights but the range of adjustment is limited the shorter you go.
Old Jan 22, 2005 | 05:29 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">7" front 8" rear</TD></TR></TABLE>
i thought it was shorter in the rear. at least for civics and crx.
Old Jan 22, 2005 | 06:10 PM
travis's Avatar
Default Re: spring height (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
i thought it was shorter in the rear. at least for civics and crx.</TD></TR></TABLE>
I don't know if that is the case for the 00 civic. The CRX certainly uses longer in the front. I figured .RJ looked it up
mazdabish
Suspension & Brakes
Feb 20, 2015 10:31 AM
redsolturbo
Suspension & Brakes
Mar 7, 2008 05:11 PM
Redsun
Suspension & Brakes
May 10, 2006 04:20 PM
sph33r
Suspension & Brakes
Oct 31, 2005 06:33 PM
D50boy
10
Mar 4, 2004 06:06 PM
