obd 0 dizzy
You dont.. If you have an obd1 ecu in your car then you need an obd1 dizzy.. The obd0 dizzy will only work in an obd0 car..
The only exception to this is if you have an AEM EMS where it doesnt matter what dizzy you have you can make it work, but thats another story all together..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrx4 »</TD></TR><TR><TD CLASS="quote">any one else i have seen it done</TD></TR></TABLE>
If you saw it done, the car must have ran like total ***.
The OBD-0 has a different reluctor wheel in it than the OBD-1 does.
They send differnt signals to the ECU and are not interchangable.
the difference is the cylinder position sensor, the obd1 has 24 teeth and hte obd 0 has 16 so at tooth 16 (one cycle, teh obd1 ecu thinks is only 2/3 through the cycle) compredi?
i'm running an obd0 dist on a z6. you have to use the ecu that matches the dist. and you'll have to modify the dist. to mount properly. i'll see if i can find the thread.
here is how i and one other person did it. his way is cleaner and more secured. doing it like this i still retained full adjustability.
https://honda-tech.com/zerothread?id=913151
remember you have to use the dist. that matches the ecu. so you'd need a pm6 or 7.
ludesrv
May 12, 2007 08:58 PM
ThaSpitefulWun
May 31, 2005 04:34 PM
