Legit block??
Old Jan 19, 2005 | 07:53 AM
Gravy's Avatar
Default Legit block??
Hey guys need some help with a block. This kid wants to sell me this block but he has no papers, he claims that the block is a honda warranty block.
kinda hard to believe but then he shows me this on the block.
and the block doesnt have a vin plate either.
I know that can be removed but it doesnt look like someone tried to remove it. Does anyone know what that R DOT stands for??
Thanks for ur help
Marcos
Old Jan 19, 2005 | 08:43 AM
GDM Z28's Avatar
Default Re: Legit block?? (Gravy)
its got the holes where a vin plate should be....the motors ive seen with out vinplates dont even have those holes.....but im not positive...call honda and ask them!
Old Jan 19, 2005 | 08:50 AM
doublej's Avatar
I am NOT 100% positive about the RDOT id but would agree it's a oem honda replacement block. I have a road racing customer that owns a Honda & Acura dealership and supplies these same blocks for his builds. Toyota has a similar marking on their blocks.
Old Jan 19, 2005 | 08:56 AM
GDM Z28's Avatar
Default Re: Legit block?? (doublej)
the kid should have papers for the reason he got the block...
Old Jan 19, 2005 | 09:11 AM
JimBlake's Avatar
You blocked out the block serial #. What's the first digit? Zero??
I've heard that factory replacement engine blocks or whole engines have first digit zero, but I don't know if it's really true?
ps. Either here or on Honda-Acura.net someone claiming to work at Honda said that. That's where I originally heard about the 1st digit being tied to the production year. But he said if it wasn't installed into a new car at the factory, then the first digit was zero.
Modified by JimBlake at 2:09 PM 1/19/2005
Old Jan 19, 2005 | 09:43 AM
Gravy's Avatar
Default Re: Legit block?? (JimBlake)
yeah the first number does start with 0. never heard of that theory. anyone else??
Old Jan 19, 2005 | 12:48 PM
doublej's Avatar
New to me also. The RDOT block I have also starts w/ zero.
Old Jan 19, 2005 | 12:57 PM
Gravy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublej &raquo;</TD></TR><TR><TD CLASS="quote">New to me also. The RDOT block I have also starts w/ zero.</TD></TR></TABLE>
does urs have the holes for vin plates??
Old Jan 19, 2005 | 01:54 PM
The Original Whitey's Avatar
The replacement block would explain why the vin plate is missing.
Old Jan 19, 2005 | 03:55 PM
dcvt16's Avatar
Default Re: (Whitey.)
we had a rdot block w/ no numbers on it, the person we got it from said they bought the short block from honda, but the oil pump broke after about 25,000 miles.
Old Jan 19, 2005 | 05:49 PM
doublej's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gravy &raquo;</TD></TR><TR><TD CLASS="quote">
does urs have the holes for vin plates??</TD></TR></TABLE>
Yes it does. Unused.
Old Jan 20, 2005 | 04:47 AM
Gravy's Avatar
so i guess im ok then. ill go ahead and do the deal. thanks for ur input fellas.
Old Jan 20, 2005 | 05:11 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gravy &raquo;</TD></TR><TR><TD CLASS="quote">so i guess im ok then. ill go ahead and do the deal. thanks for ur input fellas.</TD></TR></TABLE>Are you suspicious of the deal? Just because it's an engine that Honda didn't install into a car on the assembly line, that doesn't prove it's not stolen. Wouldn't hurt to run the serial # past the cops...
Old Jan 20, 2005 | 05:13 AM
Gravy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Are you suspicious of the deal? Just because it's an engine that Honda didn't install into a car on the assembly line, that doesn't prove it's not stolen. Wouldn't hurt to run the serial # past the cops...
Yeah but what if it is stolen. then im in a hassle and so is everybody involved. ill just give it back now that i think about it.
Old Jan 20, 2005 | 07:12 AM
GDM Z28's Avatar
Yeah but what if it is stolen. then im in a hassle and so is everybody involved. ill just give it back now that i think about it. </TD></TR></TABLE>
bro give me the serial number ill call the cops and tell them im gonna buy an engine and i just wana run the serial number to make sure its not stollen. if it is just give the engine back.
Old Jan 20, 2005 | 07:45 AM
Gravy's Avatar
Default Re: Legit block?? (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">
bro give me the serial number ill call the cops and tell them im gonna buy an engine and i just wana run the serial number to make sure its not stollen. if it is just give the engine back.</TD></TR></TABLE>
im has been sent......
Old Jan 20, 2005 | 04:01 PM
Vintech's Avatar
[QUOTE=doublej]I am NOT 100% positive about the RDOT[QUOTE]
RDOT is what they put on replacment parts, because they don't have VIN's
R=Replaced DOT= ceritfied by the Department of tranportation
Old Jan 20, 2005 | 09:20 PM
ironcheftony's Avatar
thats not a vin plate location, in the picture, look on the back of the motor on the bottom left under the alternator, the vin plate should be there since this is a b16a2 motor which is obd2
Old Jan 21, 2005 | 06:55 AM
mike-y's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">bro give me the serial number ill call the cops and tell them im gonna buy an engine and i just wana run the serial number to make sure its not stollen. if it is just give the engine back.</TD></TR></TABLE>
it might not that easy (depending on where you are). out here, you can't run engine numbers over the phone, they require you to bring the block in to the CHP. if it comes up stolen, they keep it and you are SOL.
Old Jan 21, 2005 | 11:40 AM
B18EG6's Avatar
Default Re: Legit block?? (mike-y)
some motors do not have the vin tag on the back. Not too confident, but i believe somewhere around 94 or 95 they started putting them on the back
Old Jan 21, 2005 | 11:44 AM
ralphie14's Avatar
Default Re: Legit block?? (B18EG6)
my 2001 LS has it on a green metal tag on the bottom right hand side of the block.
dschenke
Dec 16, 2008 05:49 PM
JFG Kevin
Jul 17, 2006 04:39 PM
preludesi93-arg
Jun 19, 2005 06:44 AM
Kavehman
Apr 5, 2005 06:42 PM
Rboosted717
May 8, 2003 08:33 AM
