P28 ecu Knock sensor?
Old Jan 19, 2005 | 07:46 AM
Scotty B's Avatar
Default P28 ecu Knock sensor?
Can anyone verify that the P28 ecu does not utilize a knock sensor when chipped for DOHC?
Old Jan 19, 2005 | 07:53 AM
Phatch99's Avatar
Default Re: P28 ecu Knock sensor? (nasi)
most of the ppl on this board runs the p28 ecu because it doesn't require a knock sensor but if u want proof then i'm sure there will be someone to explain this to you.......
Old Jan 19, 2005 | 08:08 AM
PrettyLude's Avatar
i can't explain why, but my friend does not have a knock sensor when he runs a chipped ecu for dohc
Old Jan 19, 2005 | 08:09 AM
mmuller's Avatar
Mad Scientist
Default Re: (PrettyLude)
the p28 ecu does not have a knock sensor board
Old Jan 19, 2005 | 09:08 AM
civic-4-ges's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">the p28 ecu does not have a knock sensor board</TD></TR></TABLE>
Agreed, there is no knock sensor board in the p28
Old Jan 19, 2005 | 09:41 AM
GDM Z28's Avatar
Default Re: (civic-4-ges)
you cant run a knock sensor with the p28 even when chipped cause the ecu does not know there is a knock sensor.....if it had the board the ECU would know what a knock sensor is then it would look for it. if you want to chip an ecu and run a knock sensor chip a obd1 GSR ecu.
Old Jan 19, 2005 | 09:39 PM
TeStUdO's Avatar
You need to run a P72 for a knock sensor.
Old Jan 20, 2005 | 08:08 AM
93_db2's Avatar
Default Re: (TeStUdO)
pretty sure a knock can be added to a p28 board
Old Jan 20, 2005 | 08:15 AM
GDM Z28's Avatar
Default Re: (dohciv420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohciv420 &raquo;</TD></TR><TR><TD CLASS="quote">pretty sure a knock can be added to a p28 board</TD></TR></TABLE>
it can you have to add the knock sensor board....but why not just buy a p72 that already has one? Also i dont like modifing ecu's.....only chipping them...i hate adding vtec to a non vtec one n crap like that
Old Jan 20, 2005 | 08:41 AM
mmuller's Avatar
Mad Scientist
you can use more than just the p72 ecu if you want a knock sensor.
But seriously, the stock knock sensor sucks; and its really not worth adding/ worrying about it.
Its really not hard to add one though
Old Jan 20, 2005 | 05:39 PM
StorminMatt's Avatar
Default Re: P28 ecu Knock sensor? (mmuller)
The P30, PR3, and P61 also look for a knock sensor. If you are lloking for a pre-1992 ECU, the PR3 (pre-1992) and PW0 also look for a knock sensor.
Old Mar 26, 2021 | 03:15 PM
Godsson92's Avatar
Im also trying to figure out how to connect a knock but I’m actually using my old harness from a 1992 eg si (doesn’t have knock ) and the motor is b16a (new to the mechanic game and didn’t know how to wire a right hand harness to my car.) so I’m trying to figure out what to do p30 computer by the way
ohsnapzafingcu
Oct 21, 2007 09:21 AM
dkrex001
Oct 1, 2006 10:34 PM
96 GSR-T
Jun 30, 2006 09:31 PM
SHG_EasyE
Jan 22, 2006 11:26 AM
PanamaVTI
Nov 26, 2003 10:39 AM
