Electrical Problem *HELP!*
Old Jan 19, 2005 | 05:41 AM
blurrrcivic94's Avatar
Default Electrical Problem *HELP!*
On my 95 DX with a swaped b16, sometimes the car will catch a CEL then start sputtering untill I come to a stop. Then it dies. When I try to restart the car, the cluster lights will flicker for a minute then completely shut off. After sitting for a few minutes, I try to start the car again and it fires up on the first try and drives fine. This happens probably every 20 miles or less. When I'm still able to drive the car after the CEL has lit, I hear a popping/crackling noise coming from the engine bay.
Anyone have any ideas?
so far I've already replaced both battery terminals and checked the distributor.
Old Jan 19, 2005 | 05:48 AM
Filthy Focker!'s Avatar
Default Re: Electrical Problem *HELP!* (blurrrcivic94)
Ok, what cel are you throwing?
fs
Old Jan 19, 2005 | 05:50 AM
Default Re: Electrical Problem *HELP!* (filthy_shovel)
when I try to pin it, it's either already gone, or it doesn't flash.
Old Jan 19, 2005 | 07:44 AM
bump
Old Jan 19, 2005 | 07:30 PM
bump
Old Jan 19, 2005 | 08:01 PM
TeamNextGenChris's Avatar
check your battery and alternator connections.maybe an ELD problem?check a manual fo the ELD troubleshooting procedure.
Chris
vtec-boy17
Feb 22, 2010 07:03 PM
Eghatch93
Feb 1, 2006 05:52 PM
