No ground wire from tranny to frame = no start?
Heres the story.
I bought an EG shell, so of course im missing a few little things. Anyways , i got an engine in and everything hooked up etc. and I noticed I dont have this thick ground wire that goes from the top of the tranny to the frame ( passanger side). When i try to start the car i hear the starter click once. Is NOT having this ground wire causing this???
im not sure if that's what's causing it to not start, but it could be, i do know that if u dont have that ground the car will not turn over, hope that helps...
i cant try it because i dont have it. i finished putting everything together tonite at 12am. and i realized i didnt have that ground.
damn i know how that is, once i finish a long *** project and something small prevents me from immediately reaping the benefits of my hard *** work. theres gotta be wire somewhere around there man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportRacr05 »</TD></TR><TR><TD CLASS="quote">Just take some 4 gauge speaker wire and try to see if it works.</TD></TR></TABLE>
just strip the end off wrap it around the screw or nut on both sides
if thats the problem go buy some connectors rings and you be set
I don't think it would cause you car to not start.
My ground was boken and my car was running fine.
but I did replace that wire with 4 Gauge Speaker wire.
I had a swap and they did not put the ground wire near the value cover. Once the ground on the trans started to loose contact I had starting problems. Just put a wire on there like everyone said.
I've also ran into this problem. I was helping a guy finish his swap. He went to crank it over and it only clicked. After making sure the battery was fully charged, I noticed he had niether the valve cover ground or the tranny ground hooked up.
He must have thrown the ground wire away, so I just jimmy rigged a couple grounds by taking 4 peices of 14guage wire, stripping the ends, twisting them together, and then bolting them down.
It worked fine and the car started right up.
rasinhell
Mar 30, 2005 03:11 AM
