98 auto EX obd2 to 5spd GSR obd1 idle PROBLEM!!!
ok i just finished this swap and now i am having a problem with the idle i even connected the positive side to the IACV on the ecu and it still doesnt register it! i did the orignal 3wire to 2wire IACV switch pin method and didnt work either!
things i have tried so far
swapped ecu's both chipped and nonchipped
swapped 3 wire to 2wire method
hard wired it to the jumper harness
i am using the correct throttle body with 2ports
the IACV works cuz i tested it with 12 volts and it opens
i am using the 98 auto harness
conversion harness to obd1 with a chipped p72
vietnamezerice
Jul 17, 2009 03:46 PM
