maintenance is red
Old Jan 18, 2005 | 08:38 PM
IRev2NineK's Avatar
Default maintenance is red
okay, after i installed my DC header, i noticed that my maintenance warning thing was red. any clues why its red? is there any way that you can reset it back to green? thanks
Old Jan 18, 2005 | 08:42 PM
murmur9's Avatar
Default Re: maintenance is red (EBPxb16a2xEM1)
lol it turns red 7,000 miles after you push the button to turn it back to green. It was not caused by the headers. Read your Honda Civic Owners Manuel!
Its just hondas saftey ****...to get regular check-ups i guess. i just reset it everytime. But of course...I always do my checkups myself...motor swap./...ya know. its nothing to worry about.
WrongWD's Avatar
push the little thingie to the left. its just chance that it turned red after you installed it. im just curious as to how you fit a dc header on with a turbo setup? domestic style turbo setup?
Old Jan 18, 2005 | 08:49 PM
IRev2NineK's Avatar
Default Re: (WrongWD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD &raquo;</TD></TR><TR><TD CLASS="quote">push the little thingie to the left. its just chance that it turned red after you installed it. im just curious as to how you fit a dc header on with a turbo setup? domestic style turbo setup?</TD></TR></TABLE>
dont have a turbo haha. prolly gonna go jrsc in the future
Old Jan 18, 2005 | 08:50 PM
IRev2NineK's Avatar
Default Re: maintenance is red (murmur9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murmur9 &raquo;</TD></TR><TR><TD CLASS="quote">lol it turns red 7,000 miles after you push the button to turn it back to green. It was not caused by the headers. Read your Honda Civic Owners Manuel!
Its just hondas saftey ****...to get regular check-ups i guess. i just reset it everytime. But of course...I always do my checkups myself...motor swap./...ya know. its nothing to worry about. </TD></TR></TABLE>
haha thanks. i was worried. i would read the owners manual if i had one but i dont
bought it from a private seller and he didnt' give me the manual so eh. but thanks, take s alot of my mind
Old Jan 18, 2005 | 08:58 PM
murmur9's Avatar
Ok...well check this out...I'm glad you got you a honda. Now...instead of asking questions you could probably find the answer to. Use search. (which i understand with this question you wouldnt be able tof ind it on search probably) And a REALLY GOOOOOOD idea would be to get you a HELMS manual. Its right next to my bible. Or maybe i should say it tooks its place? uh oh....hope there arnt too many holyrollers about to jump on my case.
Old Jan 19, 2005 | 08:18 AM
flood's Avatar
The maintanace indicator is there to remind you to change your oil.
Under Normal Conditions you change the oil every 7500 miles or 12 months. Severe is every 3750 miles or 6 months.
Old Jan 19, 2005 | 09:14 AM
90gs's Avatar
Default Re: maintenance is red (flood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood &raquo;</TD></TR><TR><TD CLASS="quote">The maintanace indicator is there to remind you to change your oil.
Under Normal Conditions you change the oil every 7500 miles or 12 months. Severe is every 3750 miles or 6 months. </TD></TR></TABLE>
7500 miles? thats quite a bit... oil would be pitch black and clumpy at that point...
i always change oil at 3000...
Old Jan 19, 2005 | 09:24 AM
green-'s Avatar
The indicator light is for scheduled maintenance...coolant, rotating tires, etc...
Check your manual.
Old Jan 19, 2005 | 09:47 AM
codyb13's Avatar
There is a couple different shades of green. So you will have to push the button a couple of times, till it gets to the lightest green. Thats what happened with me anyways.
Old Jan 19, 2005 | 10:55 AM
flood's Avatar
Default Re: maintenance is red (90gs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90gs &raquo;</TD></TR><TR><TD CLASS="quote">7500 miles? thats quite a bit... oil would be pitch black and clumpy at that point...
i always change oil at 3000...</TD></TR></TABLE>
Severe operation schedule is still 3750. The old change schedule for 3 mo / 3k miles is for old cars like my 75 corvette with a carb. It has alot more dirt/grime and blowby than any newer Fuel injected vehicle.
Although it is the "life blood" of the engine so change it as often as you like. I think that the manual suggesting 7500mi for normal conditions is fine especially since I use mobil 1 which has extended life over dyno oil.
Also I dont think the maintenance indicator is for "coolant, etc..." as these maintenance items go beyond the 7000mi / 7500mi distance it requires to trip the indicator to yellow/red. sparkplugs / air filter / valve clearance / inspect adjust drive belts / replace coolant at 30k
rotating tires at 7500 isn't a bad idea. I may need to start doing this but its kind of a pain in the ****.
Old Jan 19, 2005 | 01:09 PM
damnecheck's Avatar
its just some dumb honda thing they did to 6 gens...ignore it if u work on your own car...atleast thats how i feel about it....put ur key in to change the color....
Old Jan 19, 2005 | 01:17 PM
bustah49's Avatar
Default Re: maintenance is red (damnecheck)
HOLY ****...DON'T RUN IT..IT WILL ******* BLOW UP
ma_rio44
Sep 17, 2007 04:00 PM
KiNG $h!t
Group Threads
108
Apr 7, 2007 03:04 PM
j0hn-0h
Jan 11, 2007 11:02 AM
jumpmann23
Dec 18, 2004 02:17 PM
ImpoRTride
15
May 23, 2003 06:34 PM
