Would this work?
Old Jan 18, 2005 | 06:37 PM
Bond's Avatar
Default Would this work?
My 5-spd '92 Civic DX HB does not have a tach. I found this odd and the previouse owner (1st owner) said when he bought the car it did not come with one. I am new to this import stuff and just wanted to know if this was true and why? Also I want a tach. because it makes knowing when to shift that much easier. So my other question would be if I can go to a junkyard and pull one out of say a 5-spd Si and hook it up in my car. Would I have to re-wire or get a different ECU or harness? Help! I am in the dark on this one. If anybody could help it would be of great use.
Old Jan 18, 2005 | 06:39 PM
resol's Avatar
Default Re: Would this work? (Bond)
yeah.. should plug right up and work fine unless the cluster is messed up
Old Jan 18, 2005 | 07:09 PM
colinproctor's Avatar
any 92-95 cluster will plug right up and work in a 92-95
Old Jan 18, 2005 | 07:22 PM
92orangeeg's Avatar
search ....search........search........search
many times this question has come up
Old Jan 18, 2005 | 07:23 PM
sohcvtec1995's Avatar
Default Re: Would this work? (FdOoUoRr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FdOoUoRr &raquo;</TD></TR><TR><TD CLASS="quote">any 92-95 cluster will plug right up and work in a 92-95</TD></TR></TABLE>
yea it dosent matter if its 5 speed or automatic.
Old Jan 18, 2005 | 07:25 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: Would this work? (sohcvtec1995)
Would you need an Si underdash harness to get the Si tach to work or could you use the cx/dx underdash harness with an Si gauge cluster alone?
Old Jan 18, 2005 | 07:34 PM
Default Re: Would this work? (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Would you need an Si underdash harness to get the Si tach to work or could you use the cx/dx underdash harness with an Si gauge cluster alone?</TD></TR></TABLE>
its a complete plug and play
Old Jan 18, 2005 | 07:35 PM
Si cluster alone works. no other requirements but get the cluster and plug it up.
Old Jan 18, 2005 | 07:36 PM
Hatch It's Avatar
The tach harness or adaptor is behind your stock cluster already, just plug it into the right spot in the new cluster....simple....you can even put your old milage in the new one too by unscrewing like 4 screws and swapping it out....search is your friend
Old Jan 18, 2005 | 10:53 PM
drift9's Avatar
Im pretty sure that the EX civics come with the tach as well they might be easier to find than an Si
Old Jan 18, 2005 | 11:21 PM
VTiVTo8000rpm's Avatar
Default Re: Would this work? (Hatch It)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch It &raquo;</TD></TR><TR><TD CLASS="quote">The tach harness or adaptor is behind your stock cluster already, just plug it into the right spot in the new cluster....simple....you can even put your old milage in the new one too by unscrewing like 4 screws and swapping it out....search is your friend </TD></TR></TABLE>
What if the car came as an auto DX in my case, and now theres 5spd man. ?
Old Jan 18, 2005 | 11:26 PM
95excoupe's Avatar
Default Re: Would this work? (VTiVTo8000rpm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTiVTo8000rpm &raquo;</TD></TR><TR><TD CLASS="quote">
What if the car came as an auto DX in my case, and now theres 5spd man. ?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">
its a complete plug and play</TD></TR></TABLE>
Any trim/coupe/hatch/sedan/Auto/Stick they will all work as long as it came from a 92-95 civic.
Old Jan 18, 2005 | 11:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTiVTo8000rpm &raquo;</TD></TR><TR><TD CLASS="quote">What if the car came as an auto DX in my case, and now theres 5spd man. ?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95excoupe &raquo;</TD></TR><TR><TD CLASS="quote">Any trim/coupe/hatch/sedan/Auto/Stick they will all work as long as it came from a 92-95 civic.</TD></TR></TABLE>
here how about this. all the info you need right here.
<FONT COLOR="green">[FAQ] What parts are interchangeable for all 92-00 Civics?</FONT>
Old Jan 18, 2005 | 11:57 PM
balistik's Avatar
CX and DX clusters don't come with tach's. ^. any 92-95 civic clusters are plug and play. automatic manual. 4 doors you name it will work. That's why hondas are cool haha.
HCJDM1
14
Feb 2, 2007 04:44 AM
jdm_eg6_hatch
Aug 28, 2006 08:39 PM
delspool
Jun 27, 2006 12:33 PM
Econo'Box
Feb 9, 2005 10:57 PM
bankhead83
Mar 27, 2004 08:28 AM
