Can an ECU be repaired?
Old Jan 18, 2005 | 06:17 PM
ringgold's Avatar
Default Can an ECU be repaired?
I did a search and found that ECU's can possibly be repaired but Im not sure if this can be repaired anyways here is the situation. I had a OBD1 P72 in my car when I bought it Im not sure if this ECU had these problems before or after this happened. I was trying to get this car that I had just bought out of this guys garage and the battery was dead. Well it was dark in there and I didnt have a good flashlight well needless to say the battery wires got crossed while installing a battery and it fried a couple fuses and what not but other than that I didnt find any problems. Well the ECU that I used to get the car home with constantly threw a code for the VTEC solenoid, the O2 sensor, and one other thing cant remember. The car ran like complete crap until I got another ecu which was a chipped P28. It was crazy the ecu would actually try to engage the vtec while the car was idling and it sounded crazy I thought that I had a problem in the valvetrain and the car wouldnt idle right at all and I spent money on parts that I didnt need when all along it was that bad ECU. So my question is can this ecu be repaired by anyone? I would like to give the P72 another try since Im still running the stock GSR intake mani and its basically a stock engine. Also this P72 was for an automatic and I would like for that portion of the ECU to eliminated so I dont get a check engine light. Any insight on this would be greatly appreciated.
Old Jan 18, 2005 | 10:44 PM
ringgold's Avatar
Default Re: Can an ECU be repaired? (ringgold)
Old Jan 19, 2005 | 04:33 AM
v4lu3s's Avatar
RTFM
you wont know til you send it off to a place that does repair ecus. i know there is s upposed to be a business in houston that does that kind of work though it usually starts at around $175
Old Jan 19, 2005 | 08:46 AM
ringgold's Avatar
Default Re: (v4lu3s)
Damn its that much?? Ill just toss it or somethign if its gonna be that high priced. I wander if getting it rechipped would fix all the problems that ECU has?
Old Jan 19, 2005 | 01:05 PM
v4lu3s's Avatar
RTFM
it all depends on what got burnt on it.
Old Jan 19, 2005 | 01:22 PM
ringgold's Avatar
Well what is this place called? and do they charge just to look at it and see what is messed up?
Old Jan 20, 2005 | 06:39 AM
v4lu3s's Avatar
RTFM
i will try and find out, i heard about them through a calvage yard do work for.
as far as i know they are a large scale operation, so i would assume they will biull for troubleshooting.
allmotor-B
Engine Management and Tuning
12
Aug 29, 2011 04:21 PM
EG6 Love
Sep 3, 2010 05:23 PM
Civicman86
Nov 11, 2006 09:05 AM
jamclaur
Jul 21, 2005 09:04 AM
AznInvasion
Dec 8, 2004 06:15 PM
