ok im fuk'ed now what???
My Eagle H-beam rods are tapping, they use to knock but we replaced the bearings now they tapp SUPER!!!! sorry anyways my engine has many upgraded parts, I wanna swap a new motor in but not sure what to put in? the engine in my crx now is a B18a Block with a B20 head dont ask why. should i just go with a straight B20 or LS? I also have a T3/T4 turbo that will be put on the new engine.
thanks...
thanks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wc300zx »</TD></TR><TR><TD CLASS="quote">can a used stock LS hold boost? my buddy just got a LS vtec hes running 10psi nothings done to it internal. is this likely with most LS's?</TD></TR></TABLE>
If you tune it right it should run fine at low boost. If you want to boost the hell out of it, then build it before you put the block in.
If you get a used engine make sure you check that it's fairly healthy. Do a compression and leak down test. If it's in medium to good condition go ahead and boost it. Those things are good to 300whp fairly safely on a good tune. you can do 260 very easily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wc300zx »</TD></TR><TR><TD CLASS="quote">what about a B20 same deal? </TD></TR></TABLE>
b20 sleeves like to crack under boost pressures... Not saying that a 7-8psi wouldnt be great but that seems to be the threshhold for those sleeves from what ive seen...
ok so if I bought a used LS motor and slapped on a t3/t4 turbo at like 5psi it should be ok as long as the motors in good shape?
the t3/t4 turbo was on my old engine. its fine. i was pushing 5psi
oh yea almost forgot do u guys know any reliable honda motor websites? besides jaydm.com ? thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wc300zx »</TD></TR><TR><TD CLASS="quote">ok so if I bought a used LS motor and slapped on a t3/t4 turbo at like 5psi it should be ok as long as the motors in good shape?
the t3/t4 turbo was on my old engine. its fine. i was pushing 5psi</TD></TR></TABLE>
O dude **** yea... Just make sure its tuned because 5psi will still blow hit up if its detonating...
what are you tuning with?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wc300zx »</TD></TR><TR><TD CLASS="quote">I have a Zdyne ecu but it might be acting up not sure, its throwing wrong codes etc.</TD></TR></TABLE>
Get some Uberdata, or Hondata and go to the dyno to get it tuned. You will make more power like that and it will be more reliable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">
Get some Uberdata, or Hondata and go to the dyno to get it tuned. You will make more power like that and it will be more reliable.</TD></TR></TABLE>
and ou can run more hp since it will be tunned a lot better. Remember boost isn't what is stressfull to the engine it's the HP it produces. example: 250whp @15psi is a lot less stressfull then 300whp @6psi.
thanks for the info guys i've been on http://www.totaljdm.com looking for b18a1 motors but all they have are b18b anybody know any reliable motor retailers?
If the bearings were spun the last time, your crank journal may be bad. Replacing the bearing wouldn't fix this problem. Do you have an oil pressure gauge? Did you inspect the crank to see if it had any wear?
the oil pressure gauge doesnt work
but im fed up with it and want to start off fresh. will a b18b be fine? does it come with the wiring harness etc? almost everything i have is for a b18a. but i guess if its a B-series it doesnt matter.
dantamparacer
May 17, 2010 04:31 PM
