Need some info about my clutch setup (please)
Old Jan 18, 2005 | 02:45 PM
A.S.I.M.O's Avatar
Default Need some info about my clutch setup (please)
i just noticed that my clutch now has a lot of slack before it catches almost at the floor and this just started about two or three days ago. it has been really cold outside lately and basically it pushes all the way to the floor before it catches and it doesn't catch all the time sometimes it takes a few trys before i can put it in gear.
i am still new to the honda world i have only had the car for couple of months so i don't know a whole lot about it. basically i needed to know whether my clutch is cable or hydrolic and if i can pospone fixing this problem till my swap in spring or what i can do HELP PLEASE!!
Old Jan 18, 2005 | 04:06 PM
A.S.I.M.O's Avatar
Default Re: Need some info about my clutch setup (Sleezo controller 2)
bump (please)
Old Jan 19, 2005 | 07:19 AM
A.S.I.M.O's Avatar
still waiting for a reply help please!!
Old Jan 19, 2005 | 09:23 AM
sohc steve's Avatar
I had the same problem with my eg coupe. The pedal started sinking deep before it would grab, so I looked and it just needed some clutch fluid. The reservoir is on the left side of the engine bay on the firewall. Check it and add some more clutch fluid from autozone or something. Brake fluid works too, it's the same exact thing as clutch fluid. Mine had a leek where the clutch pedal linkage go's through the firewall through the rubber gasket. Just keep an eye on the fluid. If it's not the fluid, it could be a number of things (bad clutch, pedal adjustment, etc.)
Old Jan 19, 2005 | 09:41 AM
HitEm'Up's Avatar
Start by checking the clutch fluid?It could be a cold weather issue for it being sticky also. Whats it on??
Old Jan 19, 2005 | 07:08 PM
A.S.I.M.O's Avatar
Default Re: Need some info about my clutch setup (98JRSChatch)
i am sorry it's an 92 si eg hatch thanks for the replys any more feedback would be greatly appreciated
Old Jan 20, 2005 | 10:40 AM
A.S.I.M.O's Avatar
still waiting on a response please help a brother out looking 4 advice
onyx00
Dec 11, 2004 02:56 PM
just4747
28
Dec 5, 2004 11:30 AM
C-Zero
23
Feb 28, 2004 05:56 PM
VTEConly
Apr 28, 2002 03:11 AM
98blacksnake
Mar 4, 2002 06:16 AM
