cheap place to get unorthodox pullies?
Old Jan 18, 2005 | 02:43 PM
Tad's Avatar
Tad
Default cheap place to get unorthodox pullies?
I want to get a CRV lightweight crank pulley,
but they're like 200 before shipping from unorthodox..
kinda pricey.
does anyone know of a good site that sells these?
or a few sites would be nice actually, as the pulley I want is fairly specific,
and not too common.
i'm running a jrsc, so to up the boost I plan on getting their CRV crankpulley,
with no underdrive, and no ac or ps, so JUST the crank pulley portion,
should be super super light.
Also read on their site that the bseries ones even put out a slight overdrive..
so **** i'm not even sure how much boost it will make exaclty.. but I have a feeling
it'll be alot, as the stock crv crank should make around 8.5lbs at least..
thanks!
Old Jan 18, 2005 | 02:52 PM
JDMH22HATCH's Avatar
Default Re: cheap place to get unorthodox pullies? (Tad)
I've seen 3 boosted motors shatter oil pumps due to Unorthodox crank pulley's. They aren't factory balanced and sometimes cause worse vibrations on forced induction motors
Old Jan 18, 2005 | 02:53 PM
Tad's Avatar
Tad
Default Re: cheap place to get unorthodox pullies? (JDMH22HATCH)
oh yeah that reminds me,
I was meaning to ask. Would it be possible to take it to a machine shop and
have it balanced?
Old Jan 18, 2005 | 02:56 PM
I'm not sure. Factory crank pulleys have a material in the center that unorthodox doesn't. I've seen some in the past that have been warped, bent, cracked, etc. The last one I dealt with, I pulled off my roommates turbo b16. It was all jacked up and caused the oil pump to shatter and make some rod bearings spin
Have you looked into the Fluidamper unit? Contact Arturbo, he sells them
Old Jan 18, 2005 | 03:01 PM
Tad's Avatar
Tad
read up on the fluidamper..
looks odd..
I HAVE to have a specific crank pulley diameter to get my sc boosting right.
Old Jan 18, 2005 | 04:06 PM
The Fluidamper is an awesome unit.
But since you are boost dependant on whichever crank pulley you run, I'm not sure what else to suggest. I'm jut really iffy and against the Unorthodox racing pulley's
Old Jan 18, 2005 | 04:24 PM
Tad's Avatar
Tad
ok.
thanks.
I'd assume if I got the unorth balanced though it should be ok?
although I supose someone would have thought of that before if it did work..
Old Jan 18, 2005 | 04:26 PM
Soccerking3000's Avatar
ya you should get it balanced, it shouldnt be a problem after
Old Jan 18, 2005 | 04:39 PM
pgpunkguy's Avatar
Default Re: cheap place to get unorthodox pullies? (Soccerking3000)
if this is for a b-series engine, why not just get a civic type-r pulley...
factory balanced but you have no power steering...
you can get CTR pulleys for like $65
Old Jan 18, 2005 | 04:41 PM
Tad's Avatar
Tad
Default Re: cheap place to get unorthodox pullies? (pgpunkguy)
it's dseries,
but ppl have used the CRV crank on their dseries before..
with no problems..
I wonder if a ctr would work,
i'm guessing its also bigger, though probably not as big as a crv crank
Old Jan 21, 2005 | 02:28 AM
Tad's Avatar
Tad
well I still think the unortho crv crank is my best bet. as long as I get it balanced.
so back to the original question,
anyone know someplace that sells em cheaper than the unorth site? 200bux is a bit much for a crankpulley.
Old Jan 21, 2005 | 09:01 AM
Default Re: (Tad)
ebay lol
Old Jan 21, 2005 | 04:55 PM
Tad's Avatar
Tad
Default Re: (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">ebay lol </TD></TR></TABLE>
yeh ebay has unorth pullies..
but the chances of them having a NON underdriving CRV crank..
not good...
and yeh i've been checking.
I'll hunt down some shops that sell the stuff..
Old Jan 21, 2005 | 04:57 PM
Tad's Avatar
Tad
Default Re: (Tad)
woah i just came across this.
looks promising
http://www.titanmotorsports.com/bsficrpubyev.html
Old Jan 21, 2005 | 05:48 PM
Icey112's Avatar
get the n1 pully.
Old Jan 21, 2005 | 05:50 PM
Tad's Avatar
Tad
Default Re: (Icey112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 &raquo;</TD></TR><TR><TD CLASS="quote">get the n1 pully.</TD></TR></TABLE>
and that is???
anyhoo, I found a site with the pulley i'm looking
for for 170 and free shipping.
unorthodox wrote numerous times in their site about how
this pulley is a good choice for upping boost on JRSC's.. so I wasn't the first to
think of this.
I just hope I can get it balanced..
Old Jan 21, 2005 | 06:13 PM
Icey112's Avatar
it's the type r pulley my bad .
Old Jan 21, 2005 | 07:08 PM
stormy's Avatar
in order to balance the pulley you will have to pull the entire bottom end of your motor apart, The CTR is supposed to be dampened but still the rotational weight of the bottom end is different.
If I were you I would not spend 200 bux to shorten the lifespan of your rod bearings dramatically.
I would and am getting the ATI unit however.
Old Jan 21, 2005 | 07:11 PM
Tad's Avatar
Tad
Default Re: (stormy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stormy &raquo;</TD></TR><TR><TD CLASS="quote">in order to balance the pulley you will have to pull the entire bottom end of your motor apart, The CTR is supposed to be dampened but still the rotational weight of the bottom end is different.
I would and am getting the ATI unit however.</TD></TR></TABLE>
hmm I see..
so its not that the pulley is out of balance itself,
but rather that it doenst match the inner workings of the rods/crank spinning around in there..
makes sense..
But then wouldn't that mean that any foreign crank would have the same effect?
people use crv cranks all the time with no prob for upping boost.
And this one weighs only 1lb so i'd think that would help things?
Old Jan 24, 2005 | 12:33 PM
Tad's Avatar
Tad
Default Re: (Tad)
UP because I'm curious about this?
Endyn, and Jacksonracing sell boost upgrade crank pulleys,
they are built by endyne or JR, and obviously arent going to have
any harmonic dampening characteristics.
So does this mean that they are just as bad as an unorthodox pulley??
and what about using crankpullies from a different engine?
thnx
Old Jan 24, 2005 | 05:58 PM
Tad's Avatar
Tad
up
Old Jan 24, 2005 | 06:53 PM
DelSolDon's Avatar
Default Re: (Tad)
have you tried payntech, not for sure, but i think that they make pulleys for sc applications. maybe just b series though.
Old Jan 24, 2005 | 07:18 PM
stormy's Avatar
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">
hmm I see..
makes sense..
And this one weighs only 1lb so i'd think that would help things?</TD></TR></TABLE>
well put simply people do alot of things, replacing a crank pulley is not the end of the world for a motor obviuosly. But when I spend money I always think about the ultimate longevity, since I drive my cars very hard I can't really afford to lessen there relibility.
The factory balance has a certain margin of error so chances are it's not going to be a dramatic difference, but it's certainly not a good thing.
Old Jan 24, 2005 | 07:37 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stormy &raquo;</TD></TR><TR><TD CLASS="quote">well put simply people do alot of things, replacing a crank pulley is not the end of the world for a motor obviuosly. But when I spend money I always think about the ultimate longevity, since I drive my cars very hard I can't really afford to lessen there relibility.
The factory balance has a certain margin of error so chances are it's not going to be a dramatic difference, but it's certainly not a good thing.</TD></TR></TABLE>
Hmm,
well said.
and yeah that is why I keep bumping this,
I really want to know exactly how I would be affecting reliability..
The SAFE route to go, would be a smaller blower pulley..
but the smallest you can go will net you 8psi(maybe9 if ur lucky), any smaller and you get belt slippage.
I want at least 9-10psi..
Old Jan 24, 2005 | 09:32 PM
stormy's Avatar
Default Re: (Tad)
maybe you should figure out to what extent first. Having 10 pounds of boost sounds more like the 50 yard line than the goal post.
