vis hood fitment = bAd
Old Jan 18, 2005 | 12:09 PM
dzminiz's Avatar
Default vis hood fitment = bAd
I just bought a hood off a friend, he bought a few months ago, put it on, never drove his car, sold it to me, its off a 93 ex(2 door coupe), i have 93 si (hatch), its lined up pretty good, but doesn't wanna sit all the way down, any1 else w/ this prob? i think i can cut one of the supports a lil w/ a dremel, seems to be radiator holding it up. Not sure what to do though.
Old Jan 18, 2005 | 12:11 PM
sohcvtec1995's Avatar
Default Re: vis hood fitment = bAd (dzminiz)
Something has to be bent on the radiator support. or the hood could be warped.
Old Jan 18, 2005 | 12:12 PM
_BEN_'s Avatar
I dont remember off the top of my head but I think there is little rubber stoppers that will screw in that will fix that.
somewhere right behind the headlights.
Sorry if that dosent help.
Old Jan 18, 2005 | 12:13 PM
Default Re: vis hood fitment = bAd (_BEN_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote">I dont remember off the top of my head but I think there is little rubber stoppers that will screw in that will fix that.
Sorry if that dosent help. </TD></TR></TABLE>
i knew i was forgeting something. Yea check the hood stoppers, they are black and are right behind the headlight, on each side.
rasinhell's Avatar
Default Re: vis hood fitment = bAd (sohcvtec1995)
see if you can mess around with the latch on the radiator support. my hood used to be llike that but i fucked w/ the latch and then it shut nicely
Old Jan 18, 2005 | 12:15 PM
Laserjock's Avatar
it's not a VIS quality issue. You need to adjust the 2 or 4 rubber bumpstops. If it's high like you describe, rotate in. Vice versa if it's low.
Worst case, you may have to adjust your hood latch too. Did you put the rubber strip that was on your metal hood into the VIS hood?
darkcvc's Avatar
Blue Sedan Crew
adjust the rubber stoppers mentioned above, if it still does not fit, then it is possible that the hood is warped. Also try to mess with the latch, they can get bent.
My old one was crooked for a while because it was propped up on my hood stand for a few months straight, but later it went back to normal.
this is not a VIS quality problem though, I doubt it, they make a great product
Old Jan 18, 2005 | 12:19 PM
Rhythm's Avatar
I've got the same hood on my 93 EH3 and I had to adjust the latch before it would close. After the adjustment, the fitment was great...
Old Jan 18, 2005 | 12:28 PM
kidkombo's Avatar
Default Re: (Rhythm)
looks like the car got wrecked before..thatll cause it to fit sucky
Old Jan 18, 2005 | 01:26 PM
dzminiz's Avatar
Default Re: (kidkombo)
after messin w/ it for a while, you can see where the radiator mount has rubbed a lil on it, have to mess w/ it some more later.
Old Jan 18, 2005 | 01:33 PM
pdiggitydogg's Avatar
On mine, I put down a rubber stopper all the way down (left side) and the other 1/2 way up (right)
Then I used hood pins (like youre supposed to) to pull it down where I needed it.
Old Jan 18, 2005 | 02:06 PM
Go_Fork_Urself's Avatar
Default Re: (pdiggitydogg)
my hood fits perfect
Old Jan 18, 2005 | 02:20 PM
MassScene's Avatar
Default Re: (Go_Fork_Urself)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Go_Fork_Urself &raquo;</TD></TR><TR><TD CLASS="quote">my hood fits perfect </TD></TR></TABLE> Mine did too.
Old Jan 18, 2005 | 02:41 PM
8krdline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhythm &raquo;</TD></TR><TR><TD CLASS="quote">adjust the latch before it would close. After the adjustment, the fitment was great...
Old Jan 18, 2005 | 08:50 PM
BlueIntegraBoy's Avatar
Default Re: (MassScene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MassScene &raquo;</TD></TR><TR><TD CLASS="quote"> Mine did too.</TD></TR></TABLE>
Fitment is good, but mine has a gap between the inner part of the headlights to the edge of the hood.
Old Jan 18, 2005 | 08:58 PM
Soccerking3000's Avatar
Default Re: (BlueIntegraBoy)
mine fits awesome, but as stated before make sure the rubber bumper stops are low enough and also make sure you dont have any clearance issues with strut bars or anything
phasewest's Avatar
Default Re:
Definately play with the latch adjustment. I haven't p[ut one on yet that didn't require that to be adjusted.
Old Feb 2, 2005 | 02:01 AM
em1 Ziggy's Avatar
Default Re: Re: (phasewest)
bump for the same problem im having did u get it to fix... pm me please for little instructions
Old Feb 2, 2005 | 03:31 AM
Lmgrcivic's Avatar
Default Re: Re: (eK Ziggy)
I got mine and the hole where the latch is at on the hood for the clip that still holds your hood when you pop it was too small I had to cut this hole out alittle wider for the hood to shut and stay latched check that then again maybe it was just mine
Old Feb 2, 2005 | 03:50 AM
photec2's Avatar
Default Re: Re: (Lmgrcivic)
yeah mine doesn't fit also. it has a shitty gap on the drivers side and the Rubber stoppers dont do ****. i adjusted them and they are all the way down and my hood hits my bumper. also i have adjusted the latch all the way to the top.????
<FONT SIZE="5">WTF!!!!????</FONT>
mandoski
Oct 7, 2018 12:47 PM
Cscarlett2010
Paint and Body
Jan 20, 2016 09:53 AM
singlecamsaint
Sep 1, 2014 06:05 PM
ej6kevin515
Jan 23, 2012 07:24 PM
tweek_boii
Aug 17, 2008 12:30 PM
