About to buy a '93 EG-6 with JDM B16A2.. what should I be wary of?
Old Jan 18, 2005 | 11:26 AM
90gs's Avatar
Default About to buy a '93 EG-6 with JDM B16A2.. what should I be wary of?
1993 honda civic hatchback
130k miles on body
40k on JDM b16a2 (obd1)
AEM intake
Trust exhaust
2001 GS-R leather interior
Eclipse deck
Skunk2 coilovers (1" drop, camber and alignment corrected)
Tokico Blues
Rota slipstreams (with new yokohama avs100s and wheel locks)
VIS grade AA c/f hood
Vision corners
GS-R strut tower bar
Spoon side mirrors
Interior is immaculate, all plastic/carpet/floormats look brand new, paint is fresh, very slight wear on the stripping at the bottom of the windows
What should I look for? How much should I pay?
The guy is asking $5000... He's a manager at my work and I've worked with him for a year and a half, he knows his stuff, it was all done right.
I know a lot of you guys run b16s... this is the JDM one, is it absolutely necessary to run 91 octane? Compression ratio is like 10.4:1 right?
Old Jan 18, 2005 | 11:29 AM
sockvtec's Avatar
Default Re: About to buy a '93 EG-6 with JDM B16A2.. what should I be wary of? (90gs)
buy that while you can
edit* my friend uses regular in his stock b16 so your good, 91 isnt necessary
Old Jan 18, 2005 | 11:34 AM
90gs's Avatar
Default Re: About to buy a '93 EG-6 with JDM B16A2.. what should I be wary of? (zoomzoom92)
i'm likely to be buying it this weekend... he hasnt been advertising it for sale, just told me because he thought i'd give it a new good home
he said something about it having the JDM ecu and is tuned for 100 octane..?
Old Jan 18, 2005 | 11:52 AM
MeanstreakCivic's Avatar
Dont delay. If the body is in good shape swoop it up. And why so hesitant about 91. Just spend a couple more bucks and run it cleaner
Old Jan 18, 2005 | 11:58 AM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90gs &raquo;</TD></TR><TR><TD CLASS="quote">i'm likely to be buying it this weekend... he hasnt been advertising it for sale, just told me because he thought i'd give it a new good home
he said something about it having the JDM ecu and is tuned for 100 octane..?</TD></TR></TABLE>
If it's an EG6, it should have a Japanese ECU. If the cars been tuned for a higher octane, I wouldn't run a low octane. Even if it was stock I wouldn't run a lower grade octane.
Old Jan 18, 2005 | 12:01 PM
rasinhell's Avatar
Default Re: About to buy a '93 EG-6 with JDM B16A2.. what should I be wary of? (rodrez.)
I can't remember where I saw this investigation about how higher octane gas is pretty shitty or something.... like they do somethin 2 save money and it turns out to be same as regular. I put this on everything sombody had the link to this article but i wish i could find it
Old Jan 18, 2005 | 12:04 PM
rasinhell's Avatar
Default Re: About to buy a '93 EG-6 with JDM B16A2.. what should I be wary of? (Special-Ed)
or maybe something about how high octane gases in some cases is bad for the car or some **** i can't remember dont quote the dumb **** i say cuz i'm here to make you stupiderer
Old Jan 18, 2005 | 12:16 PM
POE's Avatar
POE
sounds like a good deal to me, get some pictures of it, and post um up? To bad you arent located in OKLAHOMA, i would be interested in your bosses car
Old Jan 18, 2005 | 06:09 PM
Chase's Avatar
U gotta use high octane, i noticed a difference in my car...its alot smoother with premium
Old Jan 18, 2005 | 07:42 PM
Mad Ra88it's Avatar
wait what!!! this is local? damn, might be cool to meet some local kids....BUY THAT CAR!!!
Old Jan 18, 2005 | 07:45 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: About to buy a '93 EG-6 with JDM B16A2.. what should I be wary of? (Mad Ra88it)
so it's right hand drive? only eg6 i know of is right hand drive.. so..
Old Jan 18, 2005 | 08:09 PM
Del Sizzle's Avatar
If you don't buy it, I will
Old Jan 18, 2005 | 10:24 PM
90gs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mad Ra88it &raquo;</TD></TR><TR><TD CLASS="quote">wait what!!! this is local? damn, might be cool to meet some local kids....BUY THAT CAR!!!</TD></TR></TABLE>
whoa a rocklin kid.. whats up? i work in roseville..
Old Jan 18, 2005 | 10:35 PM
cxSHOE's Avatar
sounds good for the price. but understand that you are in california i assume and you run the risk of not getting it smog legally at a smog station. if you have a hook up with a smog guy who will look the other way and has the old machines then go for it..
but you still run the risk of getting pulled over and having your hood popped. and you will have to go to the state ref and they wont look the other way..
but either way make sure you can get it smogged legally, if you can then cool.
Old Jan 18, 2005 | 10:36 PM
ektouge88's Avatar
or I'll buy it
Old Jan 18, 2005 | 10:47 PM
BauleyCivic's Avatar
Risky Business
Default Re: (egdrift88)
With compression that high, you need 91.
Old Jan 18, 2005 | 10:55 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zoomzoom92 &raquo;</TD></TR><TR><TD CLASS="quote">buy that while you can
edit* my friend uses regular in his stock b16 so your good, 91 isnt necessary</TD></TR></TABLE>
all dohc vtec b engines need premium, especially JDM motors with higher compression. you can use regular gas, provided that you have the knock sensor hooked up and are running the correct ecu. the timing will be retarded (read less hp) to prevent knocking.
also, make sure you get a smog certificate when you buy the car. you won't be able to legally get a smog check unless the motor has been certified by a smog ref.
by the way, there is no such thing as a JDM b16a2. the b16a2 is a USDM obd2 99-00 si motor.
Old Jan 18, 2005 | 11:13 PM
90gs's Avatar
Default Re: About to buy a '93 EG-6 with JDM B16A2.. what should I be wary of? (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">
by the way, there is no such thing as a JDM b16a2. the b16a2 is a USDM obd2 99-00 si motor.</TD></TR></TABLE>
he described it as a "second gen jdm b16 complete changeover" does that just mean its a Sir-ii engine or what? i thought it was just a b16a2...
Old Jan 18, 2005 | 11:15 PM
VTiVTo8000rpm's Avatar
by the way, there is no such thing as a JDM b16a2. the b16a2 is a USDM obd2 99-00 si motor. </TD></TR></TABLE>
Thank you, I was waiting for that *marked in bold*
Old Jan 19, 2005 | 03:36 PM
90gs's Avatar
Default Re: About to buy a '93 EG-6 with JDM B16A2.. what should I be wary of? (VTiVTo8000rpm)
picked up the cashiers check for the car today. will be purchasing on friday.
93DA9
Northern California (Sales)
Feb 27, 2011 03:29 PM
rhdsirhatch1
Apr 29, 2009 06:58 PM
pbrady
Jun 23, 2008 09:34 PM
JDMH22KID
May 16, 2006 11:48 AM
