Speaker Swap For 2 dr 98 Civic Si
Old Jan 18, 2005 | 10:13 AM
brad88nl's Avatar
Default Speaker Swap For 2 dr 98 Civic Si
I have recently purchased a new set of 6x9’s to replace my stock rear 6x9’s. When I went to replace them I was surprised to find no way to access the rear speakers (neither from the grill or the trunk ) The only way I can see accessing the rear speakers is to take the rear side panels and seat out. If somebody knows some other way id appreciate there knowledge!
Old Jan 18, 2005 | 11:40 AM
sopiwnykg's Avatar
Default Re: Speaker Swap For 2 dr 98 Civic Si (brad88nl)
you have to pull out the rear side panels, as well as the seats inorder to get the rear lid off of the car to replace the speakers. No other way is possible.
Old Jan 18, 2005 | 01:30 PM
importdreamer's Avatar
Default Re: Speaker Swap For 2 dr 98 Civic Si (sopiwnykg)
Actually, you dont have to pull the seat completely out. Just fold em down. IF you can get two people in the back seat you should (after remove a few screws) be able to lift the rear panel up just enough to slide in the speakers. Becareful when you unpop the side panels cuz the **** breaks really easy.
Old Jan 18, 2005 | 05:49 PM
civic_speed99's Avatar
Default Re: Speaker Swap For 2 dr 98 Civic Si (importdreamer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdreamer &raquo;</TD></TR><TR><TD CLASS="quote">Actually, you dont have to pull the seat completely out. Just fold em down. IF you can get two people in the back seat you should (after remove a few screws) be able to lift the rear panel up just enough to slide in the speakers. Becareful when you unpop the side panels cuz the **** breaks really easy. </TD></TR></TABLE>
Yeah they are fagile, I snapped mine behind where the seatbelt goes though, but luckily it can't be seen.
Old Jan 18, 2005 | 05:51 PM
I meant fragile before the comments start pouring in, lol.
Old Jan 19, 2005 | 11:22 AM
brad88nl's Avatar
Thanks alot for the help. Il be sure to take your advise, and be careful not to crake the panels.
Frstyl838
Jul 11, 2008 10:37 AM
xintegr
Apr 8, 2005 05:23 PM
brad88nl
Jan 20, 2005 09:18 AM
vvti_01
Jan 14, 2004 12:16 PM
h2392si
Audio / Security / Video
Sep 18, 2003 03:02 PM
