p13 ecu help (need to make it stock program again )
Old Jan 18, 2005 | 09:41 AM
machine4321's Avatar
Default p13 ecu help (need to make it stock program again )
is there a jumper to cut in this ecu ........i need to put it back to the stock bin instead of my shitty spoon crap /......thanks guys
Old Jan 18, 2005 | 11:00 AM
mgags7's Avatar
you need to either get someone to reburn you a stock chip, which will never come out right.....
when they wrote the spoon program to your chip, it erased the stock one, so no, no jumper or anything, just someone needs to burn a program to it, and it will never be as good as the stock one....
or you could just buy a new ecu....i have one to sell(hint hint)
Old Jan 18, 2005 | 11:08 AM
v4lu3s's Avatar
RTFM
the spoon [program, if it is actually the spoon one is damn near stock....
anyway you have to swap teh stock rom chip back in.
Old Jan 18, 2005 | 11:12 AM
prelittlelude's Avatar
Default Re: p13 ecu help (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">is there a jumper to cut in this ecu ........i need to put it back to the stock bin instead of my shitty spoon crap /......thanks guys </TD></TR></TABLE>
yes you can cut one of the jumpers near the chip that was intalled, i will have to fidn a picture or when you post up a pic of the inside of ecu i can tell you what to cut
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">you need to either get someone to reburn you a stock chip, which will never come out right.....
when they wrote the spoon program to your chip, it erased the stock one, so no, no jumper or anything, just someone needs to burn a program to it, and it will never be as good as the stock one....</TD></TR></TABLE>
actually you are in correct, you can not overwrite the stock bin , the way an ecu is chipped is they install a socket some resistors and a jumper wire to tell the ecu to read a none stock or modiffied bin, hence called chipping an ecu,
unless someone was an absolute idiot and did some other crazy modifications to the ecu then he can just cut the jumper,
Old Jan 18, 2005 | 11:22 AM
great to hear ..thanks man
Old Jan 18, 2005 | 11:23 AM
Default Re: (machine4321)
post a pic of the inside of the ecu once you get it open,
Old Jan 18, 2005 | 12:41 PM
i dont have web space but i can email it to yiou
Old Jan 18, 2005 | 02:27 PM
is it the j1 on the ecu ... ive heard that it will work on other ecu..but theres a resistor in that spot
Old Jan 18, 2005 | 03:12 PM
just use imagebuket or we-todd-did-racing
Old Jan 18, 2005 | 04:40 PM
im at work and the boss took the digi with him ......so i guess im outta luck
Old Jan 18, 2005 | 04:57 PM
mgags7's Avatar
i stand corrected, i figured they burned the program onto the stock chip and put it back in, overwriting the stock program....
thanks for the info
Old Jan 18, 2005 | 05:06 PM
Eddiebx's Avatar
Default Re: p13 ecu help (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">
unless someone was an absolute idiot and did some other crazy modifications to the ecu then he can just cut the jumper, </TD></TR></TABLE>
thats not how p13s work, there is no magic jumper to cut, because the stock program is already on an external rom, so what you need to do is to either pop ur stock chip back in, which sounds like you dont have anymore, or have something burn you a stock bin on a new chip and pop that one in.
shitty deal...i did on a whim desoldered the j1 resistor and at least it starts...solid cel witch means its not working
i guess ill have to get ahold of my tuner and have him ups me a new bin since i cant do these from uberdata
Old Jan 18, 2005 | 05:32 PM
Eddiebx's Avatar
hehe thats why you should come over and ask me at HS first,
Old Jan 18, 2005 | 05:46 PM
v4lu3s's Avatar
RTFM
the p13 uses an external rom stock, its not like a p28 where you add an external rom. to chip a p13 is jsut desolder teh stock chip and solder a new one in.
Old Jan 18, 2005 | 05:53 PM
sorry eddie ..umm im at work and hs is blocked by our **** filter....yea im going with that one ..
i feel bad know
Old Jan 18, 2005 | 06:13 PM
Default Re: p13 ecu help (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
thats not how p13s work, there is no magic jumper to cut, because the stock program is already on an external rom, so what you need to do is to either pop ur stock chip back in, which sounds like you dont have anymore, or have something burn you a stock bin on a new chip and pop that one in.</TD></TR></TABLE>
yep i stand corrected, my bad i was thinking of the p72/p28 faimly,
so you will need to get a chip with a h22 bin burned to it, sorry about the confusion
Old Jan 18, 2005 | 07:24 PM
Eddiebx's Avatar
yeah i forgot to mention that you were probably talkign about chipped p28/30/72s,
zrickety
Jan 27, 2009 12:12 PM
b18_racer805
Oct 28, 2006 05:38 AM
streetracerof06
16
Jun 3, 2006 08:09 PM
spoon23_JDizM AkA SpOoN20
Oct 4, 2003 11:30 AM
