fuel pump wont prime intermittently
Old Jan 18, 2005 | 07:42 AM
Turbo E's Avatar
Default fuel pump wont prime intermittently
anyways i suspect its the main relay (under the dash)
I will turn the ignition to the on position, check light goes on, but no whirring noise.
turn the ignition on and off a few times then sometimes the pump primes. start the car then it may die (no fuel) and sometimes it wont.
am i right? just wanted some feedback before i blow $300
Old Jan 18, 2005 | 07:55 AM
Filthy Focker!'s Avatar
Default Re: fuel pump wont prime intermittently (Turbo E 604)
What tests have you done to determine that it is the main relay?
fs
Old Jan 18, 2005 | 08:06 AM
Ricey McRicerton's Avatar
Default Re: fuel pump wont prime intermittently (filthy_shovel)
If you do decide that it is the culprit.
https://honda-tech.com/zero...age=6
3 posts down
Old Jan 18, 2005 | 08:16 AM
flood's Avatar
This is what the service manual has to say this is for a 96+:
Remove the fuel fill cap and ensure that the fuel pump is / is not running. You should hear a whurr for 2 seconds after the ignition is turned to the on position.
If the fuel pump does not make noise, check it as follows:
Remove the seat cushion.
Remove the access panel from the floor.
make sure the ignitino switch is off, then disconnect the fuel tank 2P connector.
Connect the PGM-FI main relay 7P connect terminal No. 4 and No. 5 with a jumper wire.
Check that battery voltage is available between the fuel pump connector terminal No 1 and body ground with the ignition switch is turned on.
If battery voltage is available, check the fuel pump ground. If the ground is OK, replace the fuel pump. If there is no voltage, check the wire harness.
Modified by flood at 9:36 AM 1/18/2005
Old Jan 24, 2005 | 11:03 AM
Turbo E's Avatar
thanks ricey, I'll give er a shot. and thanks to the other guys for your feedback.
400whp
Apr 28, 2011 02:20 PM
2ndthtsurplace
Apr 10, 2011 11:15 AM
slimsam1
11
Dec 28, 2008 01:30 AM
boostnubII
Oct 21, 2006 06:42 PM
