My new VTEC head w/ pics!
Old Jan 18, 2005 | 07:38 AM
WildPig's Avatar
Default My new VTEC head w/ pics!
Hey guys, I'm pretty new to the forums and I need a little help with my swap attempt. I just bought this y8 head and intake manifold from a guy and he said it was "complete", all I need to swap it onto my y7 block.
After researching a little bit, I'm noticing more and more things I need to swap it. I already bought a 2000 p2p ecu and wire harness too.
What else would you guys recommend me getting before the install? And what can I reuse from my old head to install this one? Thanks a lot for your help guys.
Whats this?
I know I need a fuel pressure regulator.
Pretty clean? I don't know.....
Oh and here's my new 00 civic hatch......so pretty......only equipped w/ omnipowers right now.
Old Jan 18, 2005 | 07:42 AM
jlacoy82's Avatar
71.192.16.183
Get a new headgasket, new intake manifold gasket, and I do believe whats missing from the back of the intake manifold is called an IACV, idle air control valve? Could be wrong, but pretty sure.
Head looks really good, and looks like the MAP sensor might be missing too, its supposed to be on the top of the throttle body I believe.
Old Jan 18, 2005 | 07:44 AM
WildPig's Avatar
Default Re: (jlacoy82)
Thats pretty helpful, thanks!
Any idea if the y7 map sensor and iacv will fit onto the y8 head? Thanks, keep it coming guys!
Old Jan 18, 2005 | 07:46 AM
jlacoy82's Avatar
71.192.16.183
Default Re: (WildPig)
Yup, it should, seeing as the throttle bodies are all interchangeable (for the most part) between d and b series engines.
Old Jan 18, 2005 | 07:50 AM
WildPig's Avatar
Thanks yo. I was already planning on getting all the new gaskets and such. I also read something about needing a knock sensor because y7's don't have one? Any ideas on what thats all about?
Old Jan 18, 2005 | 07:51 AM
1998 hatch dx's Avatar
IACV wont...on the y7 i think its not actually mounted to the intake just has a vaccum line running to it on a bracket somwhere..
Old Jan 18, 2005 | 07:56 AM
idol4life's Avatar
Default Re: (1998 hatch dx)
clean hatch
Old Jan 18, 2005 | 07:58 AM
WildPig's Avatar
Really? I figured that much cuz the manifolds are so different. Tonight I'm going to take my y7 apart a little to see was is interchangeable. I'm hoping that this will be a clean swap becuase I'm planning on swapping the wiring harnesses too.
Old Jan 18, 2005 | 07:59 AM
ian.'s Avatar
Default Re: (idol4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idol4life &raquo;</TD></TR><TR><TD CLASS="quote">clean hatch </TD></TR></TABLE>
Old Jan 18, 2005 | 08:00 AM
WildPig's Avatar
Thanks idol4life, yeah trying not to give in to the rice at every stoplight trying to race me.
I'm gonna keep it as clean as possible and another motto of mine is "function over form."
Well thats it for my "5 posts per 24 hours," damn trial user status
Any other help would be much appreciated, thanks for all the compliments!
Modified by WildPig at 9:18 AM 1/18/2005
Old Jan 18, 2005 | 08:09 AM
wagonis's Avatar
Sweet hatch. I know what you mean though. Just got mine 2 weeks ago and I run in to many people on the street wanting a race. Don't do it.
Good luck with the car.
Old Jan 18, 2005 | 08:17 AM
99hatch's Avatar
Default Re: (wagonis)
im workin on the same project still with my hatch. i gotta get the y8 manifold and then i should be all set. good luck
Old Jan 18, 2005 | 10:46 AM
Boosted96EK's Avatar
Default Re: (99hatch)
you gotta use ur Y7 TB on the Y8 mani... or you'll have to perform the IACV fix....
Old Jan 18, 2005 | 11:17 AM
skip.two's Avatar
Default Re: My new VTEC head w/ pics! (WildPig)
maybe this will help.
[FAQ] D16Y7 / Y8 MINI-ME WRITE-UP.... WITH PICS (56k, maybe not)
Old Jan 18, 2005 | 11:22 AM
POE's Avatar
POE
u need a d16y8 ecu to, if u didnt know that. good luck, and try to get a ex tranny to to replace that dx tranny u have.
Old Jan 18, 2005 | 11:40 AM
wc's Avatar
wc
What you are missing is the IACV.
y7 and y8 auto uses a "3 wire" IACV on the throttle body. y8 manual (b series and obd1) uses a "2 wire" IACV on the intake manifold. They are not interchangable phyiscally and electrically. As an ECU made for 2 wire IACV cannot control 3 wire IACV and vice versa.
- wei
Old Jan 19, 2005 | 08:05 AM
WildPig's Avatar
Default Re: My new VTEC head w/ pics! (wc)
Bump
Any more help guys? I'm just planning on buying an y8 IACV cuz I already have the y8 harness.
Old Jan 19, 2005 | 08:55 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
you have a 96-98 manual Y8 manifold...and head.
if you want to get it going without the Y8 head just use your Y7 throttlebody (3-wire iacv mounted on TB) and plug the holes in the back of the manifold were the manual Y8 iacv was (or buy an auto Y8 manifold with no holes).
but since your doing the head swap also...that makes things more difficult.
if you are using a manual Y8 ecu, you will need to rewire the ecu for the 2-wire iacv and you will have to get a 2-wire iacv. *question* also does the 99-00 Y8 ecu control the air injection that comes on the 99-00 Y8 manifolds? if not then any manual Y8 ecu should work, otherwise you will need a 96-98 manual ecu.
otherwise go ghetto style, if possible, just run a switch for vtec with a fuel controller and just use your original Y7 TB.
look here for more info on the auto/manual and 96-98/99-00 differences
http://www.geocities.com/joeyp....html
Old Jan 19, 2005 | 09:20 AM
WildPig's Avatar
Default Re: My new VTEC head w/ pics! (fastcrxsi90)
how do you know its a 96-98 manifold and head? How can you tell? Is that bad if I'm putting it on a 00 y7 block? More complicated?
Like I said, I have a manual y8 ecu and harness and I'm gonna buy a 2 wire IACV so it should plug right in right? I'm pretty sure that since I have a y8 harness that I don't really need to rewire anything except running this harness instead of the y7 harness. Thats why I bought it.
Old Jan 19, 2005 | 10:01 AM
92orangeeg's Avatar
did he include the vtec ecu or did you buy it after you bought the head
Old Jan 19, 2005 | 10:16 AM
WildPig's Avatar
Default Re: My new VTEC head w/ pics! (92orangeeg)
I bought the head and intake manifold from one guy and 00 vtec ecu and harness from another guy. Are they that different?
Old Jan 19, 2005 | 10:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WildPig &raquo;</TD></TR><TR><TD CLASS="quote">how do you know its a 96-98 manifold and head? How can you tell?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrxsi90 &raquo;</TD></TR><TR><TD CLASS="quote">look here for more info on the auto/manual and 96-98/99-00 differences
http://www.geocities.com/joeyp....html</TD></TR></TABLE>
well at least the manifold is from a 96-98...no air injection
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WildPig &raquo;</TD></TR><TR><TD CLASS="quote">Like I said, I have a manual y8 ecu and harness and I'm gonna buy a 2 wire IACV so it should plug right in right? I'm pretty sure that since I have a y8 harness that I don't really need to rewire anything except running this harness instead of the y7 harness. Thats why I bought it.</TD></TR></TABLE>
im not positive cause ive never owned anything newer than a 91, but i doubt that it is as easy as plugging in the engine harness and going. you may have to re-pin some of the harness at the ecu and add wires for vtec and such...just take good notes and it shouldnt be too hard...just time consuming. helms is your friend for this, figure it all out on paper before you start. i think redpepperracing.com has a online helms for ek's
Old Jan 19, 2005 | 10:38 AM
WildPig's Avatar
Ok, ok, I got this crap straight.....
I read the page about the 99-00 intake manifold having air injection...... BUT I seem to have bought a y8 head and intake manifold from a 96-98 that doesn't have air injection ..... SOOOOO I can disregard that part ........BUT my y8 wire harness and ecu are from a 00 y8 engine so it's gonna be looking for air injection that i don't have? That should work right?
Somebody please tell me if my 00 y8 ecu and harness will work with the 96-98 y8 IM and head? I hope I don't have to buy another ecu........
oh and i already have a helms manual
Modified by WildPig at 1:51 PM 1/19/2005
Old Jan 20, 2005 | 07:18 AM
WildPig's Avatar
bump
Old Jan 20, 2005 | 07:34 AM
dohcivichatch's Avatar
clean hatch man
96ferio
22
Apr 22, 2014 04:25 AM
jdmcivicsi522
Apr 14, 2006 06:05 PM
Hatchdude
Jun 30, 2005 01:37 PM
HaTcH_BmX
11
Nov 4, 2003 04:08 PM
