Higher HP spark plugs? 400whp+ (searched)
Old Jan 18, 2005 | 02:31 AM
Cyphear's Avatar
Default Higher HP spark plugs? 400whp+ (searched)
Should you continue making the plugs colder after 300whp or so? I'm running BKR7E's right now which is what people say to use for 300whp but what about the people running 400+whp?
is there a good 8 or 9 series plug to use? The NGK plug list is sooo long, theres way to many options, and not many 8 or 9's.
BTW: im running a b18b so 7 is 2 colder than stock.
TIA.
Old Jan 18, 2005 | 02:46 AM
PM-Performance's Avatar
Default Re: Higher HP spark plugs? 400whp+ (Cyphear)
you didnt look hard enuff becuase there is tons of posts on plugs.
Yes they make an 8, 9, 10 ect series
Old Jan 18, 2005 | 02:52 AM
Adi Radoncic's Avatar
On Fire!
Default Re: Higher HP spark plugs? 400whp+ (itr206)
for 400+ you need 8's n 500+ its a good idea to go with 9's
Old Jan 18, 2005 | 05:52 AM
Rod.'s Avatar
Default Re: Higher HP spark plugs? 400whp+ (newgsr)
I am still using 7's on 400+. It runs fine and no misfire during boost runs. Should I be stepping up to 8's?
Old Jan 18, 2005 | 06:00 AM
Default Re: Higher HP spark plugs? 400whp+ (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">I am still using 7's on 400+. It runs fine and no misfire during boost runs. Should I be stepping up to 8's?</TD></TR></TABLE>
You dont have to, but its a good idea.
Old Jan 18, 2005 | 05:34 PM
Cyphear's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">you didnt look hard enuff becuase there is tons of posts on plugs.
Yes they make an 8, 9, 10 ect series</TD></TR></TABLE>
i seriously did like 6 or 7 searches, there are pleanty about spark plugs, not any were on higher than 7 heat ranges though.
Anyway, Thanks. What specific plugs do people recommend?
Old Jan 18, 2005 | 05:39 PM
XXXRacing's Avatar
R5671A-8, R5671A-9 or R5671A-10 is what I would recommend. I personally have run the 9 & 10 heat ranges.
Old Jan 18, 2005 | 06:52 PM
maxspeedhonda's Avatar
Default Re: Higher HP spark plugs? 400whp+ (XXXRacing)
bump because I would like to know as well
Old Jan 18, 2005 | 07:26 PM
rhamlinii's Avatar
Default Re: Higher HP spark plugs? 400whp+ (maxspeedhonda)
I runs 8s in my car's. People that run double the horse power I do run 8s as well. The worse thing that can happen running a spark plug that is to cold, is exsessive carbon build up or maybe a missfire. They just will foul faster, from what im told.
Old Jan 18, 2005 | 08:04 PM
BoostedJeff's Avatar
Default Re: Higher HP spark plugs? 400whp+ (rhamlinii)
NGK BKR7E's with 450+ HP here
Old Jan 18, 2005 | 08:41 PM
Mase's Avatar
Default Re: Higher HP spark plugs? 400whp+ (BoostedJeff)
id recommend some NGK 5238's
Old Jan 18, 2005 | 11:37 PM
Cyphear's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XXXRacing &raquo;</TD></TR><TR><TD CLASS="quote">R5671A-8, R5671A-9 or R5671A-10 is what I would recommend. I personally have run the 9 & 10 heat ranges.</TD></TR></TABLE>
Thanks, are those NGK models? (they dont look like it). are the 8,9,10 the heat ranges? did u see reduced detonation with the colder plugs?
Old Jan 18, 2005 | 11:43 PM
Garcia-Racing's Avatar
Those are ngk #'s. I run 8's.
Old Jan 19, 2005 | 12:39 AM
project dc2's Avatar
Default Re: (Garcia-Racing)
sparkplugs.com
5238
R5671a-9
Old Jan 19, 2005 | 12:48 AM
TeStUdO's Avatar
Default Re: Higher HP spark plugs? 400whp+ (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">id recommend some NGK 5238's</TD></TR></TABLE>
I recommend these:
You can find them HERE
Old Jan 19, 2005 | 12:56 AM
liam821's Avatar
25 Year Member
Default Re: (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote"> sparkplugs.com
5238
R5671a-9</TD></TR></TABLE>
Thats what im running in my car - with a 25 thousands gap. They have been working great. Best plugs ive ever run.
liam
Old Jan 19, 2005 | 01:17 AM
Cyphear's Avatar
Default Re: (liam821)
I think I might have to try the R5671A-8's in my car. How many do i need 4? j/k
Old Jan 19, 2005 | 07:52 AM
WREKONIZE V8 KLR's Avatar
good info guys
Old Jan 19, 2005 | 08:35 AM
jazz215's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">NGK BKR7E's with 450+ HP here</TD></TR></TABLE>
doh... im using those on my car only 190hp... maybe i should try 6's.
Old Jan 19, 2005 | 01:05 PM
XXXRacing's Avatar
Default Re: Higher HP spark plugs? 400whp+ (jazz215)
I would never run anything other than an NGK in a honda...definitely not autolite. Just my opinion though.
Old Jan 19, 2005 | 03:47 PM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XXXRacing &raquo;</TD></TR><TR><TD CLASS="quote">I would never run anything other than an NGK in a honda...definitely not autolite. Just my opinion though.</TD></TR></TABLE>
Agree - i would only run NGK. Although autolites are the "Nascar plug of choice".... *rolls eyes*
liam
Old Jan 19, 2005 | 05:56 PM
Default Re: Higher HP spark plugs? 400whp+ (liam821)
AUTOLITE?!?!?!?! WTF?!?!?! Keep that in the snowblower
Old Jan 19, 2005 | 08:55 PM
Cyphear's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jazz215 &raquo;</TD></TR><TR><TD CLASS="quote">
doh... im using those on my car only 190hp... maybe i should try 6's.</TD></TR></TABLE>
Whats stock for your car? 5? i'd say you are borderline between 1 and 2 steps colder.
Old Jan 20, 2005 | 08:24 AM
jazz215's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyphear &raquo;</TD></TR><TR><TD CLASS="quote">
Whats stock for your car? 5? i'd say you are borderline between 1 and 2 steps colder.</TD></TR></TABLE>
stock is 5. i plan on picking up 6's this weekend. hopefully that will help with starts and such.
Ef Si
Aug 15, 2007 12:52 PM
lude98SH
Oct 4, 2005 06:14 AM
a1320addict
Feb 18, 2005 06:34 PM
96turbob18c
Jun 20, 2004 08:52 PM
blackccoupe
Mar 31, 2004 02:50 PM
