Rear brake conversion question on a civic?
Old Jan 17, 2005 | 08:10 PM
vtecgod's Avatar
Default Rear brake conversion question on a civic?
what's up guys need some help with this have a 99 civic dx doing a rear disc conversion to it. my question is i bought the conversion from a guy who had it on a 94 ls integra, as far as the conversion can i just swap the hups out and transfer the lines with it or do i have to take out the whole control arms and all. i have heard of people doing the swap like that can i do this change or do i have to swap everything. i got everything with the conversion the e brake lines and the control arms it has new calipers on it and the sway bars too can i do this change? help me out guys thanks.
Old Jan 17, 2005 | 08:28 PM
Luserkid's Avatar
Default Re: Rear brake conversion question on a civic? (vtecgod)
You need everything, trailing arm and all.
Old Jan 17, 2005 | 09:17 PM
JDMisGOOD's Avatar
Default Re: Rear brake conversion question on a civic? (Luserkid)
try searching
Edited by Ricey:
https://honda-tech.com/zerothread?id=1118700
-1%
Old Jan 17, 2005 | 09:24 PM
97vtecex's Avatar
Default Re: Rear brake conversion question on a civic? (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">try searching</TD></TR></TABLE>
very helpful
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">You need everything, trailing arm and all. </TD></TR></TABLE>
correct
Old Jan 17, 2005 | 09:27 PM
JDMisGOOD's Avatar
Default Re: Rear brake conversion question on a civic? (97vtecex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97vtecex &raquo;</TD></TR><TR><TD CLASS="quote">
very helpful
i can spend 3 seconds typing in "brake conversion" and get 100+ threads on it... it is very helpful! Searching is key on H-T!
edit&gt; 430 threads to be exact!
Old Jan 17, 2005 | 09:34 PM
94eg!'s Avatar
#1 Super Guy
Loved
SEARCH
Edited by Ricey:
-1%
Old Jan 17, 2005 | 09:36 PM
onePOScivicSI's Avatar
thats why i bought an SI
Old Jan 17, 2005 | 09:38 PM
Quad-Damag's Avatar
Default Re: Rear brake conversion question on a civic? (onePOScivicSI)
get 99-00 si cables the ls cables are 2 long TRUST me im runing 1 ls and 1 si and the si is a direct bolt up, and the ls is kinda lose and i can't park on real big hills, i need a si one.
and yes it will be a direct fit, im runing 94 teg full trailing arms on my civic and also 96-00 camber kits, fit them perfecly
Old Jan 17, 2005 | 09:42 PM
SOHC4life 96's Avatar
Default Re: Rear brake conversion question on a civic? (Quad-Damge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">SEARCH</TD></TR></TABLE>
I guess neither of you saw the new rule. You should be docked % now.
But yes, you will need the trailing arm and all that stuff. Check in the FAQ thread up top there are about 4 links in there about rear disc conversions.
Old Jan 18, 2005 | 08:10 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Rear brake conversion question on a civic? (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">
Guess not...
Old Jan 18, 2005 | 08:12 AM
vtecgod's Avatar
the only reason i asked is because the conversion that i got the trail arms and sway bars basically everything except for the calipers and rotors are complete rusted and would have to be cleaned and repainted black i wanted to elimnate doing that i saw in a magazine someone doing a rear conversion and just replaceing the hups.
Old Jan 18, 2005 | 10:14 AM
jlsmi2's Avatar
forget about repainting them... just clean em up and bolt it on.
Old Jan 18, 2005 | 10:56 AM
sleepyEK's Avatar
there is no problem with swapping the hubs and not the trailing arms. i went ahead and pressed in energy susp. bushings in the gsr trailing arms and swapped em. keep in mind if you do this, you should prolly get an alignment.
Old Jan 18, 2005 | 02:12 PM
vtecgod's Avatar
Default Re: Rear brake conversion question on a civic? (jlsmi2)
is the cables longer on the ls than the si is this going to be a problem running the ls cables with my car. the bushings on the disc conversion are all lockup bolts wouldn't come out have to be most likely pressed or torched out been sitting along time. should i change those or no
Old Jan 18, 2005 | 02:18 PM
hawaiianbro's Avatar
So when you do a conversion.....You really don't have to swap the trailing arms out? You can just swap the hubs and thats the main part?
Thanks,
Kaleo
Old Jan 18, 2005 | 02:49 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Rear brake conversion question on a civic? (hawaiianbro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawaiianbro &raquo;</TD></TR><TR><TD CLASS="quote">So when you do a conversion.....You really don't have to swap the trailing arms out? You can just swap the hubs and thats the main part?
Thanks,
Kaleo</TD></TR></TABLE>
Correct!
I would call them "spindles" though, not "hubs". The hub is just the unit w/ the wheel bearing & wheel studs. The spindle has the bracket that the calipers mount to & the shaft that hub mounts onto.
To remove the spindle, you need a special star bit for your rachet/breaker bar & the bolts can be a PITA to access (there are 4 on the back of the trailing arm). There are no torque measuements in the manual for these bolts, so I can't help you there.
Old Jan 18, 2005 | 05:39 PM
vtecgod's Avatar
Default Re: Rear brake conversion question on a civic? (94eg!)
so is it possible to take the torex bolts from behind the backing plate and transfer the hubs but will a 94 integ hub fit into a 99 civic dx one.
Old Jan 18, 2005 | 09:34 PM
ForcedEk9's Avatar
I forgot who said this but yea, when you clean those brakes make sure you do it with a nice hard bristled brush so you die from all that crap that floats around (I can say it but not spell it). All I've gotta say is be careful when you clean your brakes. Don't air 'em out or scrub 'em w/ a brush.
Old Jan 19, 2005 | 05:04 AM
vtecgod's Avatar
Default Re: Rear brake conversion question on a civic? (ForcedEk9)
I was actually going to have them blasted and repainted if i was to change the arms to might go that way trying to get the brakes done and my valves fixed for the show coming up soon........
Old Jan 19, 2005 | 07:47 AM
vtecgod's Avatar
Default Re: Rear brake conversion question on a civic? (sleepyEK)
how many bushings should i need do i have to replace all what do you guys think. the ones in there now have to be pressed out or torched the bolts wouldn't come out of the bushing itself.
Old Jan 22, 2005 | 06:31 PM
blue skunk2's Avatar
If you had a real si you would already have the conversion.
EFin' Kyle
39
Mar 27, 2008 08:41 AM
CLE
Feb 22, 2006 07:30 PM
respectblades
Feb 19, 2004 03:07 PM
JDMACCORD
Feb 12, 2002 09:11 PM
