b16 99-00 si axles and 95-96 gsr b18 axles the same?
are b16 99-00 si axles and 95-96 gsr b18 axles the same? (both non-ABS) or are they different. i thought they were all the same. but im just making sure
The 94-01 Integra & 99-00 SI axles are the same. Used in B-swaps with hydraulic transmissions.
The axles from the 90-93 Integra are different and used in the b16a swap with cable tranny (so i'm told?)
i have a 1992 honda civic hb CX with a B16A and i thought i had ABS so i went to autozone got a 1995 Acura integra GSR axles wit ABS but i found out that its not ABS....id doesnt matter right?.......cuz when i put them on it seems wierd its not atraight it has a little bend from where the tranny is and you know how your rotors are warped and you apply brake it feels like that some times........and lets say im goin 50 and im in 5th gear when i down shift to 4th and floor it i feel big vibration and when i let go of the gas its smooth again....need help ASAP
builthatch
May 19, 2007 02:42 PM
builthatch
Apr 19, 2007 05:54 PM
NegativeXero
Aug 27, 2006 12:52 AM
