Are 17's too big for an EK coupe
Old Jan 17, 2005 | 05:09 PM
Suzukablue's Avatar
Default Are 17's too big for an EK coupe
I've wanted to get some 17 inch rims for the past few years but all my hatchbacks cant handle it because the rub. Finally got my 00 coupe and might be able to pick up a set this week. Are 17's going to rub again on the coupe? Thanks guys..
Old Jan 17, 2005 | 05:11 PM
sohcvtec1995's Avatar
Default Re: Are 17's too big for an EK coupe (eg_ko_2)
tire rubbing will occur if your car is to low, or if the offset is not correct. and dnt listen to everyone when they say " dnt get 17's be like everyone else and get 15's or 16's"
Old Jan 17, 2005 | 05:16 PM
Suzukablue's Avatar
Default Re: Are 17's too big for an EK coupe (sohcvtec1995)
whats the right offset on a coupe? i havent dropped my car since i just it from the dealership 2 days ago. but i have no plans of dropping it to the max. any pics you guys can provide?
Old Jan 17, 2005 | 05:22 PM
i believe 40 is the right offset(dnt quote me) but you can go like about 1.5 to 2 with out problems of rubbing. unless you got a camber kit cause then it would rpossibly rub.
Old Jan 17, 2005 | 05:27 PM
Suzukablue's Avatar
cool. thanks for the info bro
Old Jan 17, 2005 | 05:47 PM
VtecAddict96's Avatar
correct offset = 45
I belive the offset on my wheels are 42.
17's are really big on a hatch. I'd suggest 16's or 15's for a hatch.
Old Jan 17, 2005 | 05:51 PM
huntarrr's Avatar
There's no real 'correct' offset.. However, civics should stay between 38-45. Rubbing depends on how low you are dropped and how you have the camber/toe adjusted.
About a 1.5" drop and 40 series tires shouldn't really rub all that much (maybe on hard corners), unless you have a camber kit (which isn't really needed unless you are dropped more than 2")
Old Jan 17, 2005 | 07:10 PM
sockvtec's Avatar
Default Re: Are 17's too big for an EK coupe (vsm98civic)
i had 17s on my hatch, and it was dropped 3 inches and didnt rub.....you can check out the pics in my sig, and buy my rims
Old Jan 17, 2005 | 07:12 PM
Sour Diesel's Avatar
17's would look terrible. Plus would rub depending on how much your car is lowered. Go 15 or 16's at most.
Old Jan 17, 2005 | 07:15 PM
WongFeihung's Avatar
Default Re: Are 17's too big for an EK coupe (B30M87A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B30M87A &raquo;</TD></TR><TR><TD CLASS="quote">17's would look terrible. Plus would rub depending on how much your car is lowered. Go 15 or 16's at most.</TD></TR></TABLE>
most ppl here at honda tech would say 15's or 16's. BUT, its your car...so if you wanna go 17's do it. its your car..do what you want.
Old Jan 17, 2005 | 07:17 PM
SkySolGra's Avatar
16s on civics look much better than 17s.. just drop the civic bout 1.5 with 16s and it'll look good
Old Jan 17, 2005 | 07:24 PM
dseriesEF's Avatar
Default Re: Are 17's too big for an EK coupe (SkySolGra)
17's equal extreme rub. 16's are okay, 15's and slammed the best!!!
Old Jan 17, 2005 | 07:27 PM
Suzukablue's Avatar
thanks for the input guys. i had 16 slips slammed before and now i have si rims as a spare set. i'll pick up the 17s tonight. i'll post pics ASAP.
Old Jan 17, 2005 | 07:28 PM
eg dash six's Avatar
Default Re: Are 17's too big for an EK coupe (dseriesEF)
my OLD civic with 17s.. these pictures are before i lowered it more, no rub unless i was going over a bump while turning. other than that it was fine.
heres the only time they really really rubbed
Old Jan 17, 2005 | 07:29 PM
Changing the size of the wheel from 17 to 15 doesnt make a difference if you can slam it or not. If it's the same width wheel with the correct tire size on it, it'll have the same properties.
Old Jan 17, 2005 | 07:30 PM
project.mu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_ko_2 &raquo;</TD></TR><TR><TD CLASS="quote">I've wanted to get some 17 inch rims for the past few years but all my hatchbacks cant handle it because the rub. Finally got my 00 coupe and might be able to pick up a set this week. Are 17's going to rub again on the coupe? Thanks guys..</TD></TR></TABLE>
my opinion 17" on a wrx, s2000, etc...YES, a civic max 16" dump it and it will look alot cleaner and nicer than any 17" cuz it wasnt meant to be, also it will throw ur speedo off a bit...but thats my 2c
Old Jan 17, 2005 | 07:38 PM
TegoDC5's Avatar
Default Re: Are 17's too big for an EK coupe (n1taboo)
IMO, looks wise....it really depends on the design/colour of the wheels. Some cars can get away with 17's and others just look plain nasty. Here's my car on 17's and compare it to the one below that, they're both same size wheels. See the difference...but they're both the same size....really makes you think....
BTW, this is not my car! I found it on cardomain.com
Old Jan 17, 2005 | 07:41 PM
JDMisGOOD's Avatar
yeah... they rubbed... lol
But on a serious note 17's are not too big... the rubbing you would notice will be minimal and only experienced under hard cornering...
Old Jan 17, 2005 | 07:49 PM
HATCHingMN's Avatar
dont go beyond 16"
unless you have an SUV
Old Jan 17, 2005 | 07:52 PM
civictildeath's Avatar
Default Re: Are 17's too big for an EK coupe (HATCHingMN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN &raquo;</TD></TR><TR><TD CLASS="quote">dont go beyond 16"</TD></TR></TABLE>
i have to agree because it takes power to turn those big *** wheels. the bigger they are the harder they are to turn hence loss of power for you
Old Jan 17, 2005 | 07:53 PM
motion's Avatar
I remember this guy with a 00 Si that had 17" Racing Harts CP8 42" offset dropped with Neuspeed Race springs with no rubbing whatsoever.
Old Jan 17, 2005 | 07:55 PM
Carbonyl's Avatar
Default Re: Are 17's too big for an EK coupe (motion)
mines dropped pretty much to pretty much the max, have like 12 threads from the bottom on my GC and it doesnt really rub unless i bust a u-turn...then again im on 15s
Old Jan 17, 2005 | 07:58 PM
Kidnkorner's Avatar
if a look is all you care about get the 17's. but from a performance aspect you want a wheel that barely fits over the brake caliper.
Old Jan 18, 2005 | 06:33 AM
Suzukablue's Avatar
Just got my set last. I really couldnt pass on those original Racing Hart C2s. Installed them last night and compared to my Si rims they are heavy as hell! I felt the loss of power too. But I guess I'm more concerned about looks so I'll keep em and my Si rims. I'll post pics tonight. Thanks guys.
Old Jan 18, 2005 | 06:39 AM
MR-MUGEN's Avatar
Default Re: Are 17's too big for an EK coupe (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">
But on a serious note 17's are not too big... the rubbing you would notice will be minimal and only experienced under hard cornering...</TD></TR></TABLE>
how do you turn
uvamosk
Sep 5, 2006 03:41 PM
Nathan007
Apr 18, 2006 10:56 AM
lojackgsr
Oct 28, 2004 06:00 PM
mushu315
Apr 27, 2004 07:38 AM
Drag_On
Feb 28, 2003 06:41 AM
