Replacing a D16Y8 with a D16Z6 in an 00 civic EX (obd2 questions and such)
My friend spun a rod bearing in his D16y8 this weekend and he needs to get back on his feet quick; Only problem with this is that to do so we'd have to throw a d16z6 shortblock in his car.
Will the d16z6 not having that crank trigger thinger by the oil pump affect the obd2 computer?
We had planned on converting his car to obd1 eventually so will we have to go ahead and do so witht he bottom end swap?
so there's no way that obd2 piece of **** will run that motor without that crank trigger?
i guess i'll have to mod another p06 and throw some p28 maps on it and find a conversion harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">you could just get the jumper harness its like 65 bucks. and you just plug it in and go.</TD></TR></TABLE>
That's what I was going to say... Can't you just use the stock p2p OBD2 EX ecu and use a OBD1>OBD2 harness? y8's and z6's are so similar (disregarding OBD), it should run pretty much perfect. Am I wrong?
a jumper harness lets you use an XXXXX computer in a XXXXX chassis. I hardwired a modded p06 (gave it teh ve-tech y0!) into my car and will probably buy a conversion harness for his since obd2-obd1 is like $50 and wiring that thing in mine was a bitch.
but yea.. all i wanted to know is if there was any way that obd2 hunk of **** would run that motor for the time being
/edit: and you have to have the obd1 computer to use the harness; we dont have one yet
I imagine it would.. but you'll have a few CEL's, including CFK sensor, (knock sensor?), and such.
Not sure if you'd have to switch dizzies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm98civic »</TD></TR><TR><TD CLASS="quote">I imagine it would.. but you'll have a few CEL's, including CFK sensor, (knock sensor?), and such.
Not sure if you'd have to switch dizzies</TD></TR></TABLE>
no you dont; obd2 distributors work with obd1 computers; same nuber of teeth in the sensor
hey, i don't mean to jack this thread, but...i searched and this came up.
I have a 96 hatch with the Y7 currently.
<U>I have: </U>
Boomslang OBD2A to OBD1 conversion harness
P28 ECU
and tomorrow a D16Z6 motor and tranny.
Did you get this running? Any problems? thanks
<U>I have: </U>
P28 ECU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laserjock »</TD></TR><TR><TD CLASS="quote">hey, i don't mean to jack this thread, but...i searched and this came up.
<U>I have: </U>
P28 ECU
back from the dead, can anyone answer his question? i will be in teh same situation
<U>I have: </U>
P28 ECU
</TD></TR></TABLE>back from the dead, can anyone answer his question? i will be in teh same situation
sportcompactpower
Apr 25, 2005 04:39 PM
