hole in the tranny
Old Jan 17, 2005 | 02:50 PM
GdmLaz's Avatar
Default hole in the tranny NEED HELP NOW PLEAASE
K i was on my way home and i hit one of those water sewage **** and it made a hole in my tranny like about the size of a dime, or penny, I tried to cover it up with jb weld but no matter what it still leaks just a lil bit like a lil drop what do u guys suggest to stop this leak by the way is a an ex auto tranny
Modified by Slammed92hbonN20 at 7:16 PM 1/17/2005
Old Jan 17, 2005 | 02:52 PM
GdmLaz's Avatar
and if you are going to tell me to just change the tranny i kno i could do that alrdy so please giv me any other suggestions lol
Old Jan 17, 2005 | 02:58 PM
B2FiNiTY's Avatar
Default Re: (Slammed92hbonN20)
weld on a new plate to cover it up but I would recommend replacing the whole case/tranny.
Old Jan 17, 2005 | 03:07 PM
GdmLaz's Avatar
the only things is that i don't want to take out the actual tranny if i do I will just replace it
Old Jan 17, 2005 | 03:16 PM
GdmLaz's Avatar
up top
Old Jan 17, 2005 | 03:27 PM
GdmLaz's Avatar
going to the movies with a hole in the tranny bump HELp
Old Jan 17, 2005 | 03:38 PM
GdmLaz's Avatar
bump
Old Jan 17, 2005 | 07:19 PM
GdmLaz's Avatar
need help
Old Jan 17, 2005 | 07:23 PM
dseriesEF's Avatar
you can get it welded but it will cost you like $50 or more. 5spd swap?
make sure that you don't run low on fluid because your tranny will be toast.
Old Jan 17, 2005 | 07:24 PM
SOHC4life 96's Avatar
You're best bet is to have an actuall plate welded on like B2FiNiTY said. And still then that won't hold it forever.
Old Jan 17, 2005 | 07:25 PM
GdmLaz's Avatar
im spraying it so i don't wanna make it stick @ least not for now... plus this tranny has a torque converter so it shifts pretty much like stick
Old Jan 17, 2005 | 07:41 PM
GdmLaz's Avatar
so basically theres nothing that i could myself to cover this up My best chance is to go get it weld
Old Jan 17, 2005 | 07:46 PM
31flavorscivic's Avatar
When I tore the bottom out of my sunfire's transmission (hitting same thing you did) I just got a new plate bolted on. I got real lucky and there was minimal damage to the top part of the case. I don't know how civic auto tranny's work, but just thought I'd share.
Old Jan 17, 2005 | 07:48 PM
GdmLaz's Avatar
wut do u mean new plate bolted on?
Old Jan 17, 2005 | 08:10 PM
GdmLaz's Avatar
I need anyother suggestions im plannin on trying to get this resolved 2morrow
Old Jan 17, 2005 | 08:24 PM
oncde again I don't know how honda auto tranny's are put together but my sunfire had like the following. Imagine an upside down tupperware bowl. That's what houses the transmission. Then it had a gasket, followed by a new plate, which is the lid.
A picture is worth 1000 words.
edit: (forgot to add this in picture). Above that lip, the tranny was virtually untouched. Had it been half an inch higher, the tranny would have been ripped from my car. Don't know how it was in your situation. I lost all my tranny fluid in about 5 minutes after the accident.
Old Jan 17, 2005 | 08:30 PM
Jim Truett's Avatar
Go and find out what you hit, and who owns it. If it was in traffic lanes, the owner is generally liable for repairs.
Old Jan 17, 2005 | 08:36 PM
civictildeath's Avatar
Default Re: (Jim Truett)
so it was just the pan that was torn??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">Go and find out what you hit, and who owns it. If it was in traffic lanes, the owner is generally liable for repairs.</TD></TR></TABLE>
but until you see the money take a lot of pics and buy new pan
Old Jan 17, 2005 | 08:43 PM
GdmLaz's Avatar
hmmmm the owner i guess is the government lol is a normal street a pretty busy streeet 2 be exact
Old Jan 17, 2005 | 08:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 &raquo;</TD></TR><TR><TD CLASS="quote">hmmmm the owner i guess is the government lol is a normal street a pretty busy streeet 2 be exact </TD></TR></TABLE>
Are you fairly low to the ground? because if no one else had a problem then dang!
Old Jan 17, 2005 | 08:56 PM
GdmLaz's Avatar
i kno im fucked the car is low and you can't get money unless ur car is a stock height
Old Jan 17, 2005 | 08:58 PM
GdmLaz's Avatar
slo_ej8
Apr 8, 2008 05:04 PM
TurboEM1
23
Apr 28, 2006 04:09 AM
Type_R_Lover
Apr 11, 2006 11:09 AM
JDMallTHEway
Jan 28, 2005 09:54 PM
lakerschamp2000
Oct 28, 2002 08:59 AM
