Automatic Tranny leaking (HELP)
Old Apr 11, 2006 | 06:34 AM
Type_R_Lover's Avatar
Default Automatic Tranny leaking (HELP)
Hey Peeps gotta a question, looking for y'all help..
my tranny is leaking and i need to replace the tranny but i dont have the mula for teh swap right now.. im saving up to do the swap cuz im putting B18C1 engine with the 5-speed tranny.. but at the moment.. i need to know if there is something to stop the leaking on the tranny..
it looks like there is a small crack about 1/4 of an inch where one of the bolt is located. i was wondering if there is anything outhere that ican use to stop the tranny from leaking cuz i dont wanna f**k the tranny..
Old Apr 11, 2006 | 08:00 AM
PandaBear's Avatar
Default Re: Automatic Tranny leaking (Type_R_Lover)
Just add a few times a week until you have the money. Honda use a different formula in their ATF so if you keep topping off with other fluid, it will change the formula and not be compatible.
If you are rebuilding or replacing the tranny anyways and really want it to STOP. Get Valvoline Maxlife ATF with stop leak (the one with stop leak, not just regular maxlife ATF). It will help a bit.
Old Apr 11, 2006 | 08:26 AM
Default Re: Automatic Tranny leaking (PandaBear)
sounds good.. hopefully they'll have that somewhere here where am at..
bt something else i was looking for is to see if there was something i could put underneath it to stop the leaking... i took it to the oil change and they guy put some kinda paint (silver look alike) pretty much to see wat can be done to stop the leaking while i get the money.
Old Apr 11, 2006 | 08:33 AM
CleanLikeJdm's Avatar
Hype-R Stalker
JB weld the hole? Cheapest fix I can think of.
Old Apr 11, 2006 | 08:42 AM
Lan's Avatar
Lan
Default Re: Automatic Tranny leaking (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">JB weld the hole? Cheapest fix I can think of.</TD></TR></TABLE>
You could stick a tampon in there! LOL JK- Clean it up then you can put some JB weld on it, that stuff works for a long time but you have to prep the surface it is going on really good.
Old Apr 11, 2006 | 08:57 AM
Default Re: Automatic Tranny leaking (Lan)
awesome. thankx a lot guys.. im gon check that out after work 2nite.. need to get that taken care of... before i do the swap..
thankx..
Old Apr 11, 2006 | 09:58 AM
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">You could stick a tampon in there! LOL JK-</TD></TR></TABLE>
Lol, that might work for some of the most horrible leaks,
but that's a completely dif kind.. plus they should make mood-simma-downing tampons,
Omg, it would be a world revolution in break through for women.
And if that JB doesn't work, I'm sure you could get some kind of epoxy for a temp fix.
Old Apr 11, 2006 | 11:09 AM
fix.</TD></TR></TABLE>
can u imagine.. lmao.. that would be jokes..
but ya meng i think im gon try the JB weld, but i gotta take all the fluid out and then try it out.. and if that doesnt work... im just gon call osama and ask him to do me the favor to bomb my car... lol JJ.. i would not do that.. lol
futurefastguy
Jun 7, 2006 02:10 PM
johnca
May 22, 2006 09:24 AM
TurboEM1
23
Apr 28, 2006 04:09 AM
lude_si_95
Oct 5, 2003 03:40 PM
