b18b
how much work is involved in putting a b16b into my civic hatchback cx?
also how much money more that the block wich is about 800 it includes Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
what else do i have to get?
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
if you want it to move on the engines power a transmission would be an ideal way to do so.
Axles
Linkage
Mounts
Engine
Trans
OBD conversion if necassary
Miscellaneous sensors that break durng shipping
that's the basics, I've done this swap like 5 times, put it in & pulled it out like 20 times.
Axles
Linkage
Mounts
Engine
Trans
