04 civic si ecu ? (obd2 to obd1?)
Old Jan 16, 2005 | 07:52 PM
KseriesSLUG's Avatar
Default 04 civic si ecu ? (obd2 to obd1?)
I'm not sure this is the right forum but I asked in the dc5 and ep3 forum. No help there. Is there any way possible to convert from obd2b to obd1 and run a chipped p28 ecu on Uberdata, or any other ecu?
Old Jan 16, 2005 | 10:46 PM
FalkenSiR's Avatar
Default Re: 04 civic si ecu ? (KseriesSLUG)
Yes there is, if you know how to wire it go ahead. There are also many places where you can get jumper harnesses. Like these one.
http://www.streetlightz.com/ecujuha.html
Old Jan 16, 2005 | 10:48 PM
PrettyLude's Avatar
interesting, i would like to know the answer to this too
Old Jan 17, 2005 | 06:35 AM
Blown90hatcH's Avatar
Are you referring to OBD2b and your car? Your car is not classified as the normal OBD2b ecu. The normal OBD2b reference covers 00-01 Integra, 99-00 Civic and 98-02 accord, etc. If you need a conversion harness for that application or any other, let me know. No middle men to worry about with no tech knowledge. No internet pinout copier like so many others.
Jason
Every OBD ECU Conversion Harness!
Old Jan 17, 2005 | 10:08 AM
hondaguyef's Avatar
Default Re: 04 civic si ecu ? (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Are you referring to OBD2b and your car? Your car is not classified as the normal OBD2b ecu. The normal OBD2b reference covers 00-01 Integra, 99-00 Civic and 98-02 accord, etc. If you need a conversion harness for that application or any other, let me know. No middle men to worry about with no tech knowledge. No internet pinout copier like so many others harness like so many others/</TD></TR></TABLE>
Jason,
Would it be possible for him to run Uberdata or any other type of DIY EMS if he converted to OBD1? I don't see why not but, I may be over looking something (I'm K-tarded ) Thanks
Phil
Old Jan 17, 2005 | 10:49 AM
Used2beAb16's Avatar
Default Re: 04 civic si ecu ? (hondaguyef)
As far as i know there is no k-series to OBD-1 conversion.
OBD2B is 99-00 SI not newer SI.
Old Jan 17, 2005 | 11:41 AM
Default Re: 04 civic si ecu ? (Used2beAb16)
Alright so going to obd1 is not a problem but what about an ecu? Is there any obd 1 ecu I could use to run the k20a3? I know the they are completely different engines but run like an older si ecu and modify it with the ignition timing and fuel maps from the k20. Would that be a problem?
Old Jan 17, 2005 | 02:37 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KseriesSLUG &raquo;</TD></TR><TR><TD CLASS="quote">Alright so going to obd1 is not a problem but what about an ecu? Is there any obd 1 ecu I could use to run the k20a3? I know the they are completely different engines but run like an older si ecu and modify it with the ignition timing and fuel maps from the k20. Would that be a problem? </TD></TR></TABLE>
If Jason (blown90hatch) can make you a Harness(K OBD-obd1), I'll make the car run.......Come on man you know that
Phil
Old Jan 17, 2005 | 05:09 PM
Researching it now and will report back on it.
Old Jan 17, 2005 | 05:36 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Researching it now and will report back on it.</TD></TR></TABLE>
for you. Customer Service at it's best
Old Jan 17, 2005 | 07:26 PM
Jim Truett's Avatar
How do you plan on controlling the intake cam sprocket? Are you eliminating the variable timing?
Old Jan 17, 2005 | 08:12 PM
Default Re: 04 civic si ecu ? (Jim Truett)
By swapping to the obd1 that would take the variable timing out of the system. Would this cause a problem?
Old Jan 19, 2005 | 05:30 AM
what about the 5 wire 02 sensor
Old Jan 19, 2005 | 05:45 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 &raquo;</TD></TR><TR><TD CLASS="quote">what about the 5 wire 02 sensor</TD></TR></TABLE>
OBD1 uses a 4 wire
Old Jan 21, 2005 | 08:32 AM
yeah but k motors use 5
Modified by Used2beAb16 at 5:18 PM 1/23/2005
Old Jan 21, 2005 | 08:38 AM
mmuller's Avatar
Mad Scientist
yes they do.
Old Jan 24, 2005 | 06:48 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 &raquo;</TD></TR><TR><TD CLASS="quote">yeah but k motors use 5
Modified by Used2beAb16 at 5:18 PM 1/23/2005</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">yes they do.
It doesn't matter what o2 sensor the "motor" uses it's what the ECU reads. Hence the reason when doing A OBD0-OBD1 you must switch the 1 wire for the 4 wire.
Phil
Old May 24, 2005 | 10:50 AM
quicksol95's Avatar
the o2 sensor should not matter
but i don't see it being possible,
1. if it was hondata would not of spent so many hours developing a new program for the k-series
2. how would a obd1 or any older ecu control the new i-vtec?
also if you have k-pro (like said in your sig) why don't you use that?
Dcaustin156
Jan 9, 2014 06:56 AM
Joeski99Si
Sep 4, 2008 10:18 AM
MaxxdoutSRT4_EK9
Jun 26, 2005 10:23 PM
itr1244
Apr 29, 2005 06:01 PM
