Help with BOV clearance in hybrid (92 civic with b18c1)
Old Jan 10, 2002 | 09:39 PM
karmannghia's Avatar
Default Help with BOV clearance in hybrid (92 civic with b18c1)
Hello, I am in the process of installing the Drag 3 into my 92 Civic with B18c1. Everything is going well. However, as I am installing the Greddy Type S BoV into my skunk manifold with Holley throttle body. It's sticking too high. It is obvious I will have a hood clearance. I've been doing a search and seeing people having hood clearance with their Wastegates, but I am not having problem with that. The skunk manifold is a little higher than the stock manifold to begin with, so what is the altenative to this?
Old Jan 11, 2002 | 06:37 AM
Default Re: Help with BOV clearance in hybrid (karmannghia)
Maybe some pics would help to describe my problem. In the first pic is the complete engine bay. Can anyone tell me where the item #1 goes to? ( I presume its part of the air filter piping). Then here comes the main problem; if I raise the #2 to meet the throttle body, the BOV would then be sticking straight out of the hood. In the second pic, you will see the obvious hood clearance.
Old Jan 11, 2002 | 07:04 AM
Willard's Avatar
#1 goes on the air intake side of the tubo.
It seems to me that you have a GSR drag kit for you car... but you do not have the GSR intake manifold. The GSR unit has the throttle body lower than the ITR (?) intake manifold.... that would give you the clearance for the hood.
Will
Old Jan 11, 2002 | 07:30 AM
Default Re: Help with BOV clearance in hybrid (Willard)
As in my previous post, I did say I have a skunk 2 intake manifold. Those manifold sits higher than the stock GSR.
Old Jan 11, 2002 | 07:35 AM
Willard's Avatar
As in my post... it looks like you have a GSR kit...
I suggest getting a ITR (or B16 SI) intake tube to help with the issue.
Will
Old Jan 11, 2002 | 08:10 AM
Ahhh, now I understand where you getting at. Duhh, thanks...Let me call up my vendor and see what they can do about it.
Freshdot
May 10, 2010 09:13 AM
ATS*Mark
Feb 22, 2004 11:02 PM
TRE_
Feb 3, 2004 09:30 AM
cjmech
Aug 26, 2002 06:49 PM
GruvyTune
Oct 22, 2001 05:00 AM
