Oil leak question
Old Jan 16, 2005 | 04:35 PM
h23vtec_dc2's Avatar
Default Oil leak question
question... my car is hella leaking oil as if it was getting drained.. i checked the oil plug on the pan and thats not it.. checked everything else to see if it's loose or what.. oil filter, pressure switch, checked, cam seals, etc..
well i then decided to just change the oil and filter everything.. started the car back up and same thing.. so my question is.. what can it be back there that can make that big o oil flow..?? thanks
Old Jan 17, 2005 | 10:33 AM
Default Re: Oil leak question (h23vtec_dc2)
anybody?
Old Jan 17, 2005 | 06:25 PM
jason190's Avatar
Non turbo i'm assumming? It could be the oil pressure sensor in the back above the oil filter. ( at least that is where mine is) Maybe it came loose. Or worse case it could be the head gasket going. My head gasket went but the car wasn't over heating. And was leaking oil from the back of the block.
Old Jan 17, 2005 | 06:59 PM
showbiz's Avatar
valve cover gasket/headgasket ect ect... If its that hard to trace the leak to the source clean it up really good and use some die.
Old Jan 17, 2005 | 10:23 PM
ScoobCivic's Avatar
crank main seal......i figured mine leaks from there....its all over my tranny and shift linkage. check there
Old Jan 18, 2005 | 06:11 AM
PrettyLude's Avatar
clean it up really good and go from there
Old Jan 18, 2005 | 08:43 AM
Default Re: (PrettyLude)
okay here we go... well, i cleaned it very well. and it only leaks when i start the car up. soo.... stupid as i am, i attempt something dumb. i got my bro to start the car up while i get down there. i see that it started coming out above from the oil filter. my bro has a prelude block laying around, so i check to see what can leak oil around there. only thing i saw was this hose that connected from the oil filter part to the block.. can that be it? is that a sorce of oil line? i was thinkin bout taking that off, but it's a mother to get them clamps off.. so now im thinking bout taking the manifold off or head.. which i wouldn't like to. any other suggestions? can it really be the head gasket? cause my car runs great still. no signs of a blown gasket. thanks for your help guys. keep them coming
mrspeedy69
14
Feb 5, 2012 11:48 AM
civic89si666
Mar 12, 2008 12:54 PM
B16CivicEX
May 30, 2006 03:15 PM
96coupe
Dec 18, 2005 01:14 PM
anirtak
Mar 16, 2004 06:16 PM
