Misfire...??
Old Jan 16, 2005 | 12:42 PM
mikester_91's Avatar
Default Misfire...??
I got my valve lash adjusted a couple days ago....and my head is still pretty noisy, so what would that be?? When it idles, it kinda feels like it misfires every now and then, you can hear it in the exhaust like it's cutting out and it takes awhile to start up after sitting for a few hours. When i hooked the test connector up to the check engine light it kept blinking a bunch of different combinations....so i didn't know where to start.
Old Jan 16, 2005 | 12:49 PM
Hawkze_2.3's Avatar
Default Re: Misfire...?? (mikester_91)
Tell us all the codes it blinked.
Old Jan 20, 2005 | 01:53 PM
Okay...it blinked:
1. 9 brief flashes
2. 1 long flash, accompanied by 2 brief flashes.
3. 1 long flash, accompanied by 5 brief flashes.
Old Jan 20, 2005 | 01:58 PM
98TypeSH's Avatar
Default Re: (mikester_91)
codes 9,12, and 15
Code 9 is the CYP Sensor located inside the dizzy. You should ohm test to see if its the sensor or if your housing is toast.
Code 12 is your EGR Valve. It may be so full of carbon that its stuck open.
Code 15 is ignition output signal. Im not even sure for this one.
civicboy420
Sep 25, 2011 06:05 PM
snowblind7x
Jan 28, 2010 07:37 AM
mikej94civex
Dec 17, 2009 07:40 PM
Malgerus
Aug 15, 2002 07:06 AM
White Lightnin
Jun 28, 2002 09:15 AM
